May 16, 201610 yr comment_704597 Guys can anyone help me with the wiring under my steering i need a basic diagram for the wire color and what it is for please lights and indicators and instruments acting up. I want to rewire them before i go the way of putting relays on the lights. Report
May 16, 201610 yr comment_704599 Hi Naim, I gather from your Avatar pic & your other posts, that your need for a basic wiring diagram & wire colours, is for a KE70. Altezzaclub has posted just what you wanted back in 2014 in another thread. You should be able to obtain all the info you need at the following link. http://www.rollaclub...ram#entry688373 Trust this assists. Cheers Banjo Edited May 16, 201610 yr by Banjo Report
May 17, 201610 yr Author comment_704607 Hi Banjo thanks for this bro will take the whole dash apart this weekend and start rewiring the the faulty wires hope I can do it over the weekend. Report
May 17, 201610 yr comment_704616 Hi Naim, When you get the wires repaired, don't stop there. Go for the relay conversion, as you mentioned. It will improve the voltage to the headlights, & light output, as long as you take the relay supply power directly from the battery via a fuse. There are a couple of relay conversion wiring diagrams on this forum. I think Altezzaclub has a good one, I've seen. http://www.rollaclub.com/board/topic/33874-lousy-ke7-lights/page__p__375535__hl__+relay%20+conversion#entry375535 Cheers Banjo Edited May 17, 201610 yr by Banjo Report
May 17, 201610 yr comment_704618 You can buy an entire plug and play relay kit off eBay for under $20. Report
