Run it on manifold vac.
You will still set the idle advance to 8-10deg without vac, then set the idle speed when you connect the vac up. (adding vac will increase the idle speed) If it pinks at all just retard the timing until it doesn't. Manifold vac adds about 5deg more advance than ported vac when driving, but obviously 10deg more at idle when the ported vac is closed off.
The figures I measured are all in my topic about fitting an electronic dizzy and changing the spring rates to make it work.
I've run on manifold vac, ported vac and both at once at different times.
Link to comment
Share on other sites
I tried different advance settings and when set at around 15 degrees (with vac from manifold connected) the starter cannot start the car when hot. So I'm using around 12 degrees with vac on and that way it runs well.
It's the second starter I use with exactly the same outcome (not new tho)
I'm running around 12,5 bar in each cylinder which may be the cause of the hard cranking when hot.
Edited by Viterbo
Link to comment
