  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Ke70 Diff??!?!
Question, what diff can i use in my ke70 that can handle the power of a factory sr20det black top that wont blow blow my bank. 💀
Edited by Green_bucket
repharse
So you want a bolt in cheap high power capable diff for a 40 year old low powered car.
I want a three way with Miranda Kerr, Kahili Blundell and Myself but that doesnt mean its possible.
Most people look for a hilux diff with lsds available and shorten and modify.  Costs a lot but any good thing does.
As the man says, the hilux is the common swap.
You might wander around a van wrecker with a tape, there are a lot of vans with 5-links and rear discs these days. I'd aim for the lightest casing you can find, and ute diffs designed to lug a ton or more offroad won't be light. In the end all that weight is bouncing up and down under a very light car.
