MrTimmah Posted December 26, 2018 Report Posted December 26, 2018 I have a 79 Ke55 and the oil pan gasket is leaking. Do i need to lift the motor to swap it out or can i get the pan out around the cross member? Quote
altezzaclub Posted December 27, 2018 Report Posted December 27, 2018 In theory you can do it in the car, but its a dog of a job. The new gasket has to go under the oil pump, which goes down low in the sump. KE70 sumps have studs in the front 4 holes which means the sump has to drop a lot to clear them, I'm not sure about your KE55. I lifted the motor as high as I could without taking it out to do it. So the radiator hoses came off but most everything else stayed attached. A better way would be to lift the motor a little and drop the crossmember, only 4 bolts and two engine mounts there. With the 6-speed in the rally car the only way to get the motor/g'box out will be to drop the crossmember and let it hang on the steering arms/castor rods, and having done it a few times a day in the last week it gets pretty simple. Quote
Banjo Posted December 27, 2018 Report Posted December 27, 2018 (edited) Hi Tim, Quote I have a 79 Ke55 and the oil pan gasket is leaking. Is the oil pan gasket leaking in just one place, or in several places ? I've come across leaking oil pan gaskets, that can be fixed, by just going around & tightening each & every sump bolt & nut, without the pain of replacing the oil pan/sump gasket in situ. If the gasket appears to be leaking at the rear, there is always the possibility that it is really a leaking rear oil seal, which can appear to the untrained eye to be a leaking oil pan gasket. If the sump area is a big oily mess, I'd run the front of your car up on the ramps; tighten every sump flange nut & bolt; give the whole area a good dousing of "aerosol degreaser"; hose it all down with a bit of pressure; let it dry; start up the car & take it for a 20 minute run; run it up on the ramps again, & see if it really needs the gasket being replaced, or is just isolated at one point. If the oil leak is right at the front, (quite common) then the leaking oil gets "blown" back over the entire sump, & looks a lot worse than it really is. Let us know how you go. I can assure you "Altezzaclub", above is quite correct, that replacing the sump gasket, with the engine in the car is a "dog of a job", & you'll finish up swearing a lot ! Cheers Banjo Edited December 27, 2018 by Banjo Quote
Banjo Posted December 27, 2018 Report Posted December 27, 2018 I just remembered, I once changed an oil pump, & a set of big-end bearings, in my KE55 coupe, without removing, or lifting the engine, but just supporting it, & removing the front cross member altogether. As Altezzaclub, suggests. It is not such a big job, & you have very clear access to the bottom of the engine, as the following pics display. Quote
parrot Posted December 27, 2018 Report Posted December 27, 2018 That's awesome! And scary at the same time! Quote
Banjo Posted December 27, 2018 Report Posted December 27, 2018 Only "scary", if you have an "aversion", to K Series engines falling on your head. phobia an extreme or irrational fear of or aversion to something. "she suffered from a phobia about birds" synonyms: abnormal fear, irrational fear, obsessive fear, fear, dread, horror, terror, dislike, hatred, loathing, detestation, distaste, aversion, antipathy, revulsion, repulsion; More aversion a strong dislike or disinclination. "they made plain their aversion to the use of force" synonyms: dislike of, distaste for, disinclination, abhorrence, hatred, hate, loathing, detestation, odium, antipathy, hostility; someone or something that arouses a strong dislike or disinclination. "my dog's pet aversion is visitors, particularly males" synonyms: abnormal fear, irrational fear, obsessive fear, fear, dread, horror, terror, dislike, hatred, loathing, detestation, distaste, aversion, antipathy, revulsion, repulsion; Quote
MrTimmah Posted December 27, 2018 Author Report Posted December 27, 2018 Awesome help thanks guys! I'm upgrading from a 4 speed to a 5 speed tonight so ill start with checking the rear seal and making sure everything is tight. Awesome pics btw. Quote
Banjo Posted December 27, 2018 Report Posted December 27, 2018 Hi Tim, Is the 5 speed G/B you've got, originally from a KE55, or a later KE70 ? Cheers Banjo Quote
MrTimmah Posted December 27, 2018 Author Report Posted December 27, 2018 Update: ke70 5 speed. Took out the 4 speed and found my tunnel cut and cross member drilled already so at some point someone put a 5 in it and then swaped a 4 back in which is weird. Here is a pic looks like rear main leaking Quote
Banjo Posted December 27, 2018 Report Posted December 27, 2018 Most definitely leaking; & probably for some time. Remove the aluminium seal housing & replace. A very good idea to replace the gearbox spigot bearing in the crankshaft, while you are at it, if it feels in any way a bit "dry". or you can sense any movement, with your little finger. Good luck ! Cheers Banjo Quote
MrTimmah Posted December 28, 2018 Author Report Posted December 28, 2018 Do i need to remove the housing? Pretty sure i can sneak the old out and new on without disturbing the pan and housing. Plus the housing has studs so would have to drop the whole pan for clearance? Quote
Banjo Posted December 28, 2018 Report Posted December 28, 2018 Hi Tim, Personally I would not try to prise the seal out, with it in situ in the engine. Too much risk of scoring the seal journal on the crankshaft. By removing the seal holder, without lowering the sump, again, you will probably damage something. Just clean the whole sump pan gasket mating area, & get all that accumulated rubbish off, then lower the sump itself, at the back, & take the aluminium seal housing out. Cheers Banjo Quote
