June 15, 200620 yr comment_123530 Well I'm nearly ready to begin the swapover to make my car a manual, and there is only one last uncertainty left that i need to sort out...and that is; Will the existing starter motor from my auto work with a manual? or will i need one off a manual ke70? thanks guys, youve been great help so far :jealous: :D Report
June 16, 200620 yr comment_123692 i think it should do. i run a ke10 starter to turn over my 5k. it works fine. Report
June 16, 200620 yr Author comment_123732 i think it should do. i run a ke10 starter to turn over my 5k. it works fine. was your car previously auto? Report
June 16, 200620 yr comment_123741 no it wasn't. i was moreso commenting on how interchangable the starters are, a 1968 starter on an 82-84 engine. actually thinking about it, i did convert a mates ke30 from auto to manual. we used the same starter. Edited June 16, 200620 yr by Felix Report
June 16, 200620 yr comment_123745 Same. We did Auto to Manual convert on a KE35 and used the same starter Report
June 18, 200620 yr comment_123937 my '69 ke18 starter would jam up on the '81 starlet flywheel....... Report
June 18, 200620 yr comment_123945 I currently have a auto ke30 starter motor on my ke55e. they are somewhat different however but still fit. the original one had the solinoid sitting out on a 45o angle from the top and the auto one pretty much sits straight up. but yeah still fit!! :) Report
June 18, 200620 yr comment_124054 there is 3 different startermotors for k series toyota, the bosch, nippondeso, and some other thing, they all interchange, anything from a ke10 to a ke70 auto or manual, but sometimes you need to remove the LH eng. mount to get them in to the hole in the bellhousing if you happen to be putting the odd one into the wrong car (then you just put the mount back on when your done) Report
June 19, 200620 yr comment_124101 i dunno, there was something different about the flywheel/ring gear on mine, it may just be demographics though Report
