hey all i got ke20 rolla n i wanna do an engine conversion...apart from replacing the stocka'z 1200 with a 1300....what else is reasonably easy to do n low budget? also how the hell do i get the tie rods off so i can get the struts out....iv belted it to death with a hammer but to no avail..the stupid thing is seized..any help appreciated...cheers lads n lassies
hey, there's plenty you can do to these motors for a bit of cheap power. the 1200 is called a 3k, the 1300 is called a 4k. whack a 3k head on a 4k and you raise the compression, nice and easy power. you can change the carb for a bigger one, get more air in which means more power. on a stock motor, something like a factory 1600 carb (gemini, datsun, toyota) makes a good mod, or a weber dcd, a dgv is probably too big. you can also use SUs or sidedrafts, but you usually want to pay someone to set these up really properly. run it on bp ultimate (no additives needed for unleaded) and set your ignition timing to 10 or 12. put extractors and a 2" exhaust on it (no bigger). improve your ignition system, lots of people give good reports on transistor coils (ie: bosch gt40), get some nice low resistance ignition leads
check out my faq for some info on these cars, welcome to owning an oldcorolla :)
thats the way med man.......
hang on a tic while i put down this 4 pound slegdy and getmy 9 pound out.....:)
Yes cutting them off is a bad idea. The big hammer idea is cool, except just be careful you don't bend anything you're not meant to. Also it can put a lot more stress on things like your steering knuckles if you bash them with the hammer, and stress fractures on steering knuckles is no fun.
Pullers are fun. For real. I have like a MASSIVE set of pullers, and apart from the trusty "wire brush on angle grinder" I'd say that my pullers are the most awesome thing ever :)
