October 8, 20242 yr comment_737037 Hey Rolla crew, Finally finishing up cleaning my Corolla and looking to start modding it. I’ve got a set of front xt130 struts that I want to convert over to adjustable coils for my KE30. Doing some research on the adjustable weld on kits available and I hear AJPS isn’t around anymore. T3 still has their kit. What are people doing nowadays with converting them over? What’s the best bang for buck option? I’ve got access to a welder and down the track I’d be doing the Pug/Hilux brake upgrade and going to 14 inch wheels as well as resetting the rear leaves. If anyone running a ke30 sedan with a similar setup has any advice I’d be all ears : ) cheers Report
October 8, 20242 yr comment_737038 I'd suggest having a good read through the Rollaclub website, & you'll find a wealth of suggestions, & experiences of others, including myself, going back many years. I just popped in KE30 front brake upgrade, into the search box at the very top, of this page, & it found 37131 references, & 1486 pages, where this subject was covered or canvased. Good Reading ! Cheers Banjo Report
October 8, 20242 yr comment_737040 Check out the BCRacing coilovers at Justjap, and Manon Racing brakes in NZ. BCR have coilover kits that get welded into your strut base, and kits complete with a stub axle. Manon do brake kits for 13" and 14" wheels with Wilwood calipers. I'm organising both for my KE70, but you may find gear that will fit. PerformanceSuspension as PSR are also local and have a wider range of springs for their sets. They do XYZ shocks with them. Report
October 9, 20242 yr Author comment_737042 Cheers guys, had a look thru forums but wasnt sure if the info was up to date as some parts used for conversions were from places not around anymore. Report
October 11, 20242 yr comment_737045 I'd find the weight everything you're thinking of fitting,the weight of the XT130 setup put me off it in the end. The last thing you need on a light-weight Corolla is a lot of unsprung weight pounding up and down. Report
