Fraggle Posted August 5, 2006 Report Share Posted August 5, 2006 Just wanting some info and yes I have searched and searched but found nothing OK I might be able to get complete KE71 with 4A and 5 speed question is :P Will the 5 speed bolt up to a 4k in a KE71. Thanks in advance Stuart Quote Link to comment Share on other sites More sharing options...
lappy Posted August 5, 2006 Report Share Posted August 5, 2006 The gearbok off a 4A motor most likely a T50 so it wont bolt up to a 4K you will need a K50 (5-speed) or K40 (4-speed) Quote Link to comment Share on other sites More sharing options...
KE354AGE Posted August 6, 2006 Report Share Posted August 6, 2006 I think you mean AE71...and why on earth would you bolt a 4k into an AE71? it would have to be a really special 4k to be dropped in in favor of a 4ac... I'm not exactly sure what youre trying to do...use an AE71 gearbox in a KE70 with a 4k or put a 4k into an AE71...anyway, no, the 4k wont bolt up to an AE71 t50 gearbox, nor will it bolt to the AE71 crossmember, you will need to get a KE70 crossmember, and get a K50 or K40 gearbox from a KE70, youll also need to convert an AE71 to cable clutch using a KE70 pedal box...if thats what youre trying to do...alot of work, and why? Quote Link to comment Share on other sites More sharing options...
Fraggle Posted August 10, 2006 Author Report Share Posted August 10, 2006 I think you mean AE71...and why on earth would you bolt a 4k into an AE71?it would have to be a really special 4k to be dropped in in favor of a 4ac... I'm not exactly sure what youre trying to do...use an AE71 gearbox in a KE70 with a 4k or put a 4k into an AE71...anyway, no, the 4k wont bolt up to an AE71 t50 gearbox, nor will it bolt to the AE71 crossmember, you will need to get a KE70 crossmember, and get a K50 or K40 gearbox from a KE70, youll also need to convert an AE71 to cable clutch using a KE70 pedal box...if thats what youre trying to do...alot of work, and why? To clear it up I have a 71 with a 4k and 4 speed (4K-C was in it ) :D I have just purchased a 71 with 5 speed (blown engine 4A) Spares :) was looking to swap gearboxes so it don't rev it's date out an longer runs. Quote Link to comment Share on other sites More sharing options...
jamesrolla Posted August 11, 2006 Report Share Posted August 11, 2006 i think he means he has one of the ke70's with the slant fronts and he also has an ae71 and he wants to put a t50 on the back of his 4kc in the ke70.. it might fit but i don't know, you would probably need the t50 cross memeber and all the pedals and slave cylinder shit etc... you might have to redrill some stuff to make it bolt on the back but i can't tell you wether it will fit because i have never done it before, if it works i would like to know because i have a couple of t50's here and i might stick one on the back of my 4k cheers james Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted August 11, 2006 Report Share Posted August 11, 2006 As posted previously, K50 gearboxes and T50 gearboxes are completely different. K50s use a cable clutch, T50s Use a hydraulic clutch (Cable clutch T50 bellhousings are rare). There is no way you will get a T50 behind a K motor without a K - T bellhousing. Quote Link to comment Share on other sites More sharing options...
coln72 Posted August 11, 2006 Report Share Posted August 11, 2006 And it would be easier to find rocking horse shit than one of those bell housings....... Quote Link to comment Share on other sites More sharing options...
Rolla__Boy Posted August 11, 2006 Report Share Posted August 11, 2006 I think you mean AE71...and why on earth would you bolt a 4k into an AE71?it would have to be a really special 4k to be dropped in in favor of a 4ac... It would have to be a DAMN special 4AC to choose it over a standard mostly f@$ked 4K in my opinion!!! I agree with Nick, 4K all the way Quote Link to comment Share on other sites More sharing options...
Fraggle Posted August 14, 2006 Author Report Share Posted August 14, 2006 Ok picked up the 71 4a today cam shaft is not moving seized up, bottom half still turns over pulled the cam out today has anyone got a 4a head and cam they don't want???? just want to see if it goes any good..... What sort of power with a good cam would it make????? Or should I just wreck it and build up a monster 4K Thanks all for your help Stuart Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted August 14, 2006 Report Share Posted August 14, 2006 Sure the timing belt hasn't snapped? Quote Link to comment Share on other sites More sharing options...
Fraggle Posted August 15, 2006 Author Report Share Posted August 15, 2006 Sure the timing belt hasn't snapped? No cam shaft is rooted and the head to I think got some groves in the housing for the cam and broke a cap on top of the siezed section of cam as well So I need head for sure and a cam.............Anyone ????? Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted August 15, 2006 Report Share Posted August 15, 2006 Only reason I asked is thats why Nicks AE71 wouldn't run when we first got it, Never seen a cam seize before.. Quote Link to comment Share on other sites More sharing options...
Fraggle Posted August 15, 2006 Author Report Share Posted August 15, 2006 will take a picture tomorrow so you say you have seen one!!!!! Quote Link to comment Share on other sites More sharing options...
