August 26, 200620 yr comment_136877 hello boys and girls i am in the proces of buying a 3k bigport to put onto a fresh 4k(as soon as i rebuild it) all i need to know is what i need to do to it so it dousnt blow up like lloyds :y: little lloyd has informed me that i should get the rods ballenced and shot piened can you tell me what else i need to do if you need a list of mods sing out thanks casey Report
August 26, 200620 yr comment_136881 what are you going to do with it???? Know of plenty of K's that see 7000rpm plus that run standard rods. Report
August 26, 200620 yr comment_136935 i put one on my old 4k, all i did was take the 4k head off, i did a rough valve regrind in my shed at home, sanded all the faces down, put new gaskets on and slapped the 3k bigpot head on with the 4k rocker gear because the 3k stuff was seized, works well for me but now i just have to tune my newest addition to the car which is a 40mm dellorto, made a lot of diffrence to drive it now, lost soe down low but got more up top Report
August 27, 200620 yr comment_137048 For f@$k sake nick, someone should talk to admin. :y: "Know of plenty of K's that see 7000rpm plus that run standard rods." How long do they like that for though? Report
August 27, 200620 yr comment_137135 Muller - my 5K has been seeing 7000rpm plus for 4 years and the 3K before that used to clock the tacho (8000rpm) for 3 years. Report
September 5, 200620 yr comment_138854 all of ours here were bigports until like '75 i have a totally rebuilt 3kc bigport head, i couldn't use it because with flattop pistons i had around 250lbs of compression with dished pistons, you should be able to run it ok f.s. if you're interested, i ran this less than 1,000 mi after paying $250 usd to have it done Report
