Trufauru Posted September 7, 2006 Report Posted September 7, 2006 Hi everybody, I'm Sebastian from San Jose - Uruguay, and I'm just about to buy my first car a ke70. I been reading the forums all over but i can't found the answer to my question, the corolla that I'm buying, has the 4K engine resting in the back completly dismanteled. I can find for free a 4E-F engine but no T50 gearbox so I was wandering if de 4E could be mounted easily with the K50 gearbox. Sorry for the bad English, i wait for your answer ;) Quote
Hiro Protagonist Posted September 7, 2006 Report Posted September 7, 2006 Hi everybody, I'm Sebastian from San Jose - Uruguay, and I'm just about to buy my first car a ke70.I been reading the forums all over but i can't found the answer to my question, the corolla that I'm buying, has the 4K engine resting in the back completly dismanteled. I can find for free a 4E-F engine but no T50 gearbox so I was wandering if de 4E could be mounted easily with the K50 gearbox. Sorry for the bad English, i wait for your answer ;) Welcome to RollaClub Trufauru/Sebastian, on't worry about your English, it seems fine to me, and most of the people here are very open and supportive I'm not sure that the E-series engines even came out in RWD format, so the first hassle would be simply making up engine mounts/crossmembers etc. Then you'd have to track down an E-K bellhousing (if such a thing exists, and if E-series engines weren't used as RWD then I doubt they would exist) Quote
Trufauru Posted September 7, 2006 Author Report Posted September 7, 2006 OK,:P, my first post, my first mistake, the engine that i can put in the rolla for free is an 4A-F not a 4E-F, oooops. I read the FAQ and i can't find info on a bellhousing form A to K, there are A->T or A->W but no A->K Quote
Trufauru Posted September 7, 2006 Author Report Posted September 7, 2006 :P I just found this on wikipedia, but i don't know if its correct, here it go: K50 Ratios: First Gear: 3.789:1 Second Gear: 2.220:1 Third Gear: 1.435:1 Fourth Gear: 1.00:1 Fifth Gear: 0.865:1 Applications: - All 5-speed Starlets and Corollas with K-series engines, - 1986 Corolla with 3A-U and 4A-U engines My thiking is, if the K50 came with the 3A-U and the 4A-U , its very posible to fit also the 4A-F, or there is a big difference beetwen these Quote
irokin Posted September 7, 2006 Report Posted September 7, 2006 4A and 4E are completely different engines. The 4E has only ever been mounted transverse. The closest you'll get to a RWD gearbox is out of a 4wd Tercel. 4A is 1600cc 4E is 1300cc Quote
Foxtail Posted January 10, 2007 Report Posted January 10, 2007 There is a guy down the coast who put a 4AF in a KE36 panelvan. He cut a hole in the firewall for the dissy, I gave him twin 40mm solex carbs from a 2TG but I don't know it he used them. It looks like 4AF and 20V extractors are the same bolt pattern. Quote
