Ke55 Axles In Ke20 Diff
12die4
Theres 2 models of diffs:
The Aus diffs are the Aus Borg Warner rear loading centres, no housing
The Jap diffs have the Jap front loading centre in a complete housing.
There are 2 diff widths and pcd's
The ke2x has 1320mm diff drum face to face measurement (4x110mm pcd)
The ke3x has the 1355mm diff drum face to face measurement (4x114.3mm pcd)
Not sure on interchangability but someone mentioned cut down axles of the same model would work,
most likely same model with different type of width cut down to suit, maybe some research could be
worthy as last i looked the 4x110mm pcd flange is too small to redrill to 4x114.3mm pcd flange.
Edited by styler
Link to comment
Share on other sites
Yeah my KE20 has a Banjo so I would find a KE30 with one. But is the banjo diff in a KE30 the same as one from a KE35? (assuming KE35's ever came with a Banjo diff) I don't want to overlook KE35's parts if they will work the same as KE30 parts.
I just don't want to get a KE35 banjo and not have the axles work in my KE20 banjo diff if that makes sense?
Link to comment
