sleepercorty Posted August 20, 2008 Author Report Share Posted August 20, 2008 motor is looking a bit sad so have decided to do the rebuild while its still running and doesnt have a rod throught the side of the block. oil pump seems to be starting to give up. have big plans for the car so am not going to do a half arsed job so will probably be 6 months before it sees the road again, havent decided how far i want to go but somewhere between 320rwhp and 400rwhp is the goal. reserve car is getting ready for powercruise (1jz cressida) so it now has 3 inch exhaust and some more boost and deciding weither to do dump pipes before powercruise. Quote Link to comment Share on other sites More sharing options...
sleepercorty Posted November 16, 2008 Author Report Share Posted November 16, 2008 Car is alive again with new motor which now has acl .5mm (20thou) forged pistons, spool conrods, arp head studs, acl multi layer headgasket, acl extra series bearings, cam gears, 3 angle valve job. We pulled turbo down and fitted a bigger shaft and wheel but still having surging problems over 16psi (probably has someting to do with still running a .48 exhaust housing) so am changing to a .7 split pulse t3 housing and a bigger shaft and wheel again. While its apart i am also making to new exhaust manifold as i am currently running a chinese stainless one, so should be able to pick up another 10-20rwhp with the bigger housing and better manifold but the dyno will tell that soon enough. Injectors will be the next hold up as they are only 440cc so think they will but an end to the fun at about 300-320rwhp but they will have to do for now while i save for cams and bigger injectors. I'm hoping that 300rwhp will get me somewhere around 11.7 at 116mph. (previously ran 12.07 with 274rwhp). I will post some pics when manifold is getting closer. Quote Link to comment Share on other sites More sharing options...
sleepercorty Posted March 11, 2009 Author Report Share Posted March 11, 2009 about time i pulled my finger out and got it going Quote Link to comment Share on other sites More sharing options...
oh what a nissan feeling! Posted March 14, 2009 Report Share Posted March 14, 2009 Love your work mate. engine bay is tidy. manifold looks the goods too. Not sure how big you want to go for the injectors, i have a set of 550cc sard, just been cleaned if youre interested. Quote Link to comment Share on other sites More sharing options...
sleepercorty Posted March 14, 2009 Author Report Share Posted March 14, 2009 engine bay all back together just got to make new exhaust now. will let you know on the injectors going to see how i go with the 440cc first. Quote Link to comment Share on other sites More sharing options...
sleepercorty Posted March 22, 2009 Author Report Share Posted March 22, 2009 anybody know where to buy decent camshafts for a ca18? does anyone local do them or are there only tomei and so on available? Quote Link to comment Share on other sites More sharing options...
sleepercorty Posted March 24, 2009 Author Report Share Posted March 24, 2009 dyno friday drags saturday all going well Quote Link to comment Share on other sites More sharing options...
SLW42 Posted March 24, 2009 Report Share Posted March 24, 2009 tighe cams do them there should be something on ROCKET INDUSTRIES website man www.rocketind.com.au Quote Link to comment Share on other sites More sharing options...
quest Posted March 25, 2009 Report Share Posted March 25, 2009 anybody know where to buy decent camshafts for a ca18? does anyone local do them or are there only tomei and so on available? since you're on that side of the globe, u can probably reseach this. In thread here; http://www.nissansilvia.com/forums/index.p...345355&st=0 owner told me, that impressive/torquey CA18 ran a pair of "256 degree Duration - 8.9mm lift regrinds from Wade cams.... direct drop-in" Perfect for my needs. A couple austarion.com clubmembers extremely pleased with their Wade regrinds Tones old 20G CA18 street beast (on sxoc) ran Piper "reprofiles". I've seen other motors perform fabulously using regrind cams... as I've ran one in my old pushrod toyota 3TC. Made a startling difference! I actually spanked 2 hondas with that little 2 dr sedan. When I let off and they pulled up alongside, I rolled the window down and said, "v-tech that!" lol So I know for a fact a quality designed/reground cam can work well. Interested in your results if u go this route If no luck with the Wade (or Tomei), I'll probably hit up Iskenderian cams in the u.s., as they did the cam for my 3T. Revitalized CA18 interested seems like there is a market, where Tomei limited production may not cut it Quote Link to comment Share on other sites More sharing options...
oh what a nissan feeling! Posted March 26, 2009 Report Share Posted March 26, 2009 brian crower cams are always good value, they pop up a bit secound hand. Locally in bris there are quite a few cam shops, there is a place called 'camshaft engineering' from memory, they were real cheap. then ivan tighe are a good price too, i know crow cams does all the jap cams now too but they are pricey. Quote Link to comment Share on other sites More sharing options...
sleepercorty Posted March 26, 2009 Author Report Share Posted March 26, 2009 will see how i go on the dyno tomorrow and decide where to go from there as i don't think its going to make as much as i want. so might have to take you up on those injectors if you want to pm me what you want for them. Quote Link to comment Share on other sites More sharing options...
sleepercorty Posted March 27, 2009 Author Report Share Posted March 27, 2009 looks like will be buying camshafts before the drags doesnt seem to want to make any more power and cams are the only thing i can think that is still a restriction. will also get some injectors and then back to dyno soon. Quote Link to comment Share on other sites More sharing options...
sleepercorty Posted March 28, 2009 Author Report Share Posted March 28, 2009 few mods so far, cat convertor now flows alot better :) rb20 throttle body fitted(was about 5mm bigger than standard one) and 600cc injectors are in. going to make a call monday about regrind camshafts probably something around 270 degree 8.8 lift. Quote Link to comment Share on other sites More sharing options...
sleepercorty Posted April 2, 2009 Author Report Share Posted April 2, 2009 did a bit of road tuning and cat convertor was definately the problem had partly blocked up and wouldnt make power past 5000rpm. camshafts were to dear so just used a non turbo ca18 intake cam which has 6 degrees more duration and .7mm more lift than the turbo intake cam. so hopefully will give a little gain. should be ready to go back on dyno soon. Quote Link to comment Share on other sites More sharing options...
oh what a nissan feeling! Posted April 3, 2009 Report Share Posted April 3, 2009 Nice find with the cat, you could have spent a while chasing that one. Looking forward to hearing the results! Quote Link to comment Share on other sites More sharing options...
