Yes only a couple of weeks till i make a trip to the drags if its still going by the end it might be coming back to you for a retune with race fuel. I bought a pintara today so now i have spare gearbox, diff gears, axles and motor so no holding back i say.
Ohh.... Race fuel :lolcry: Then I can really get serious. This could get fun. Not going for a juiced up fuel before the BC drag day?? I still have some here ;) Will be a while till I will be using it again.
Yes... i just heard about that pintara too.
Ohh.... Race fuel :( Then I can really get serious. This could get fun. Not going for a juiced up fuel before the BC drag day?? I still have some here ;) Will be a while till I will be using it again.
no not going for a juiced up run yet wait to see what it runs how it is then after a week when I'm sick of it will go for the good stuff and back on dyno see how far we can push a standard ca till it go pop.
went for a trip to willowbank last night and managed 12.07 at 112mph, was fairly busy and only got a couple of runs so that didnt give me much of a chance to try different tire pressures or play with boost. mph is fairly slow as was only running around 16-17psi not 20psi because was having trouble with boost spike so was probably only making around 250rwhp. I'm going to have a bit of a play with boost to gain a couple of mph and return on a day thats not to busy and pretty confident that can go closer to 11.7 at 115-6mph. i was running mickey thompson 205/50 e/t streets and although they arnt the biggest tire a small skid and 18psi tire pressure was enough to run 1.669 60ft and just lift the passenger side tire off the ground.
Good to hear them tyres are working so well, i have a set exactly the same i can't wait to try.
12.07, so close to an 11 you can taste it. :(
Last time i went down there the lineup was about 5 cars deep,
the time before that it went right around the corner,
you never can tell if its gonna be a good night to race or not :(
Come on boys i can fit 225 / 50s under there. Your just not trying. :(
Lifting the wheel of the ground? Good work!
You CA18 / SR20 boys are running quick times in the ke30s. Well done!
yeh they do a 225 in a e/t street as well but profile is starting to get to big so will stick with the 205's. got to try make some money this week so i can try and afford a set of cams and start building a motor should not be long till mid 11's are happening.
no motor wont be in before powercruise still need to buy lots of parts, still deciding what to do with the turbo needs to be lots bigger. does anyone know what sort of power 440cc injectors will cope with?
heading to willowbank again next sunday hoping to have a little play and see if it has an 11 how it sits. if it doesnt then turbo is coming off for a mate to modify and might race it a jamboree. anyone else entering qld powercruise end of august?
replaced head gasket last week and raced again sunday but couldnt better the 12.07 that i ran last time so turbo is off already and is getting modified throught the week. hopefully will have it back by weekend and maybe tuned again next week ready for return to the drags.
