ohnoes
Welcome Guest ( Log In | Register )
2 Pages V   1 2 >
Reply to this topicStart new topic
> Sidedraft Questions
mighty_4k
post Jul 7 2010, 03:46 AM
Post #1
New Member
Group: Members
Last Active:
7th September 2010 - 10:02 PM
Hey guys I got a few questions about sidedrafts I will be putting twin dhlas on my 4k soon. I have read on a few different websites now that I will have to upgrade my fuel pressure regulator is this true or will my factory reg be capable of doing the job? I would also like to know where I could purchase linkages from as I wouldn't have a clue where to find them, thanks.
Go to the top of the page
+Quote Post
corollaart
post Jul 7 2010, 05:56 AM
Post #2
Common Member
Group: Regular Member
Last Active:
5th September 2010 - 06:28 AM
Real Name: rob
You can run them with std fuel pump with a inline regulator.Better still run a electric pump and do away with mechanical pump.
Remember dellortos ,weber only need very low pressure 2.5-4psi max or youll create problems.
I m running a electric pump that is 3.5 psi and flows 70 litres per hour.(weber }
Try nardek in sydney also stewart wilkins motorsport I'm sure there are many more .
Factory regulator ,would only be what the fuel pump is pumping out,not a regulator as such .(correct me on this)
Just remember fuel pressure is critical on these carbs.
rob
+Quote Post
philbey
post Jul 7 2010, 08:59 AM
Post #3
Your friendly neighbourhood nuisance
Group Icon
Group: Tech Moderator
Last Active:
Yesterday, 04:40 PM
rob's pretty much covered your question.
No there is no factory regulator.
I used a Holley Red fuel pressure regulator, easily found for around 30-50 bucks. You will need a fuel pressure gauge as well, a speco one with an adaptor will mount straight to the regulator.
Linkages, I would just use the redline linkage kit, take a look at my wagon engine and you'll see how it's been set up. Link in my signature.
This post has been edited by philbey: Jul 7 2010, 08:59 AM
Take a Geez at my KE16 Wagon thread with the details of my 5K buildup. Click for Enlightenment...
For more enlightenment along the path of 2 wheeled mayhem..... My Yamaha XS650 Custom
+Quote Post
Sloth
post Jul 7 2010, 06:57 PM
Post #4
Driftin' AE86 style!
Group Icon
Group: Senior Member
Last Active:
Yesterday, 10:39 PM
When we put the twin SUs on my 55 we ran an electric fuel pump and inline regulator (like everyone as mentioned). We got the manifold, linages and ramflo air filters from Lynx in Sydney (I did a quick google and I think this is their site http://www.lynxcorp.com.au/main.php?idx=home). My dad ordered the parts and apparently he was able to get them to knock a little off the price (although this was 4 or 5 years ago now).
We had some issues with the fuel pumps when we first installed them. The first model we tried was a square shaped one, and we ended up going through two or three of them (seemed to die on hot summer days and I think one time when I only had about 5 litres left in the tank). After we went to one that is more cylindrical shape and haven't had any problems since. I don't know what the difference is, or what the different styles/models/brands are, maybe someone else who knows more can shed some more light on it.
The SlothMobile
KE55 with a 7K running twin 2" SU's
The Sprinter
20v AE86
+Quote Post
corollaart
post Jul 8 2010, 06:21 AM
Post #5
Common Member
Last Active:
Real Name: rob
Electric pumps should be mounted at the back as they push fuel better than they suck,with a filter between tank and pump.
+Quote Post
etchris
post Jul 8 2010, 05:53 PM
Post #6
I'm new here
Group: Members
Last Active:
6th September 2010 - 02:50 PM
Real Name: chris
can u use the standard fuel pump with Solex Carbies? there off an 18rg
+Quote Post
corolla_bitten
post Jul 8 2010, 07:09 PM
Post #7
NA all the way
Last Active:
22nd July 2010 - 07:31 AM
yes you can you the standard factory fuel pump, i have been on my rolla for 3 years, no problems so far, and i have got massive cam and ported head and bigger valves and extractors.
ke70-4k, twin solex 40mm's, stage 2 cam, orange with simmons. Well one day.....
im busy, F**k OFF!
+Quote Post
etchris
post Jul 8 2010, 09:03 PM
Post #8
I'm new here
Group: Members
Last Active:
Real Name: chris
thanks corolla_bitten
+Quote Post
mighty_4k
post Jul 9 2010, 05:08 PM
Post #9
New Member
Group: Members
Last Active:
Thanks for your responses guys cleared it up for me big time. I'm gonna stick with my factory fuel pump purely just to keep costs down this build's costing be enough already lol-crying.gif So all I have to do is mount the fpr between the fuel pump and the carbs? What do you guys think of the following reg do yous think it will do the job?
http://www.jcwhitney.com/fuel-pressure-reg...t/p2011023.jcwx
http://cgi.ebay.com/ebaymotors/EMPI-9091-V...sQ5fAccessories
Yeah I know its not a Holley but I like to be a little different lol and I know that Empi is a good reputable brand so I know I'm not getting a crappy made unit.
Thats a bloody nice wagon by the way Philbey!
+Quote Post
mighty_4k
post Jul 29 2010, 11:53 PM
Post #10
New Member
Group: Members
Last Active:
So I ended up buying a Holley but I haven't got a clue about the fittings. I measured that the threads on the Holley and they are 15mm and the size of the factory fuel line is anywhere between 6-8mm it was hard to measure roughly cut fuel lines please note my measurement skills suck so I'm probably a mm or 2 out on the Holley threads as-well. Could someone please tell me what the correct measurements of both the Holley threads and factory are? Also What are the sizes when their converted to inches and AN? Thanks.
+Quote Post
Scoobzd
post Jul 30 2010, 12:03 AM
Post #11
Regular Poster (Caption Editable Now)
Last Active:
Yesterday, 10:41 PM
Real Name: Andrew
You don't need a pressure reg !
71 - 73 2T-G Celicas ran a mechanical fuel pump on the twin Mikuni Solexs then changed to an electric pump in '74.
18RG/GUs are the same btw !
This post has been edited by Scoobzd: Jul 30 2010, 12:05 AM
53 Celicas AND counting..
We've more parts than e-bay WORLDWIDE ! - I've CHECKED... ;)
Fanatic - WHO'S A FANATIC ?
Not us !!
It's just a HOBBY :D
+Quote Post
philbey
post Jul 30 2010, 09:38 AM
Post #12
Group Icon
Last Active:
Yesterday, 04:40 PM
QUOTE (Scoobzd @ Jul 30 2010, 12:03 AM) *
Scoobzd mate, you're just part the problem, what you've said is horseshit.
mighty_4K is running DELLORTO's and you definitely need an FPR on them.
You've just come in and told him he doesn't, and then quoted the some shit about 2TG celica's and solex's.
+Quote Post
snot35
post Jul 30 2010, 09:58 AM
Post #13
Common Member
Last Active:
3rd September 2010 - 09:37 AM
See, I was always under the impression that there is in fact a regulator in the factory fuel pump. There has to be, as even a stock carb is built to run at a particular fuel pressure. However, I wouldn't be surprised if it isn't a particularly good regulator, as it's designed to supply a small carb that isn't particularly accurate at times. Once you start upping the fuel delivery requirements, along with running a better tune, this will only highlight its inabilities.
But I think the general answer would have to be, get a good regulator. At the end of the day it's going to make getting a good tune on the delly's so much easier.
+Quote Post
Taz_Rx
post Jul 30 2010, 10:06 AM
Post #14
Brappn or boostn
Group Icon
Last Active:
Stock mechanical pumps are BUILT to supply a certain pressure..... to match the carby they're supplying, so thats why most don't have regs.
Even the '74 electric pump change Scoobzd mentioned would probably be built to supply a pressure that isn't too much for the solexs.
So this doesn't mean you can just chuck any electric pump on a set of side drafts and be all good. no.gif
I am just a worthless liar, I am just an imbecile. I will only complicate you, trust in me and fall aswell.
TAR - KE55E 5KTE. T25G, 7K EFI, T50...all the good stuff!! :)
DIRT - KE55E 3/4kc. 4k w/- 3kBP head, 609 lumpstick, weber, extractors & exhaust etc....all the left overs!! :P
MUD - KE36 7KC. Stock as a rock (apart from 7k) +AC!! Soon to be turning 4 wheels!! :0
Un-named RX4 - 13bbp, weber, 2x2.5 ex, lensos....too much more to list!! :?
Maruti (Suzuki) LWB Sierra - Hmm, I wonder what I can do with that!?
+Quote Post
Scoobzd
post Jul 30 2010, 10:51 AM
Post #15
Last Active:
Yesterday, 10:41 PM
Real Name: Andrew
Okies, so the LOW pressure USA off the shelf electric pump ($95) from Super Cheap that's been feeding my
TWIN side draft 35yo 40mm Mikuni Solexs on my Twin Cam 2T-G for 5 years now wont work?
Not us !!
+Quote Post
2 Pages V   1 2 >
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version | SEO by MinervaSEO Time is now: 10th September 2010 - 02:56 AM
  Page top
Im4eversmart
