Jul 29 2010, 12:10 PM
Post
#1
I drive for enjoyment ![]() ![]() ![]() ![]() Group: Regular Member Posts: 111 Joined: 31-August 08 From: Taree Member No.: 6534 Last Active: Today, 12:19 PM Real Name: Simon |
So to begin....the gasket blew on tuesday, so on tuesday night i put a new one in.....and all went well everythying was running smooth. THEN
Was heading for the Sydney yesterday morning to have a look at a car and got near wyong and this happened. The hose running to the heater core split (it by passes the heater core and just runs around, was like that when i got it so I'm guessing it was disconnected because the core was leaking or something) It was clamped on the end of the hose in front of where it split, then i push it along a little further and clamped behind it so i could try drive the car back home....It didnt want to drive lol. The hose seemed fine when i stuck it back on, was still soft, not hard and perished. ![]() so i pulled it apart this morning and found the gasket like this. ![]() close up it looks like this I didnt take the gasket off where its missing there, it got blown off somehow. Does anyone know what the hell went on there??? ![]() so here is why it didnt want to hold onto its coolant anymore, when i tried to start it without the radiator cap on it short coolant out the top of the radiator about 20cm high lol ![]() and really close up ![]() Should i have put holes through the gasket there??? The water jacket runs through there, raid somewhere your not spost to put extra holes in the gasket because certain ports are blocked to make the coolant flow around the whole engine and not take short cuts. Its the same as the old one so i figured it was fine to go in as is. This post has been edited by skd30: Jul 29 2010, 12:11 PM |
Jul 29 2010, 12:20 PM
Post
#2
![]() Brappn or boostn ![]() Group: Posts: 4807 Joined: 6-March 06 From: Launceston Tas. Member No.: 1315 |
Should i have put holes through the gasket there??? The water jacket runs through there, raid somewhere your not spost to put extra holes in the gasket because certain ports are blocked to make the coolant flow around the whole engine and not take short cuts. Its the same as the old one so i figured it was fine to go in as is. No don't put holes in where it doesn't have them. You're right with the water circulation around the motor. That always causes those blocked holes to do that a bit. Did you get the head skimmed before putting the new gasket in? If not then that would explain why you've just done another gasket so quickly. I made this mistake once.... " Yeah its a K motor, I don't need to plain the head"...... slapped it back together and blew another head gasket 25km later. -------------------- I am just a worthless liar, I am just an imbecile. I will only complicate you, trust in me and fall aswell.
TAR - KE55E 5KTE. T25G, 7K EFI, T50...all the good stuff!! :) DIRT - KE55E 3/4kc. 4k w/- 3kBP head, 609 lumpstick, weber, extractors & exhaust etc....all the left overs!! :P MUD - KE36 7KC. Stock as a rock (apart from 7k) +AC!! Soon to be turning 4 wheels!! :0 Un-named RX4 - 13bbp, weber, 2x2.5 ex, lensos....too much more to list!! :? Maruti (Suzuki) LWB Sierra - Hmm, I wonder what I can do with that!? ![]() ![]() ![]() ![]() ![]() |
Jul 29 2010, 12:49 PM
Post
#3
No i didnt, i used a very sharp chisel and scraped all the crap off myself. Ive done it lasted. So the gasket wouldnt have gone because it overheated cause of no coolant? i only notice pretty late, there was steam coming out the back of the car and then i looked at the temp gauge and its way up there. I just assumed it blew through cause it was roasting??
Jul 29 2010, 01:07 PM
Post
#4
Known Member ![]() ![]() ![]() ![]() ![]() ![]() Group: Regular Member Posts: 641 Joined: 22-November 06 Member No.: 2532 Last Active: Today, 12:59 PM |
did the gasket blow in the same place as last time?
also get yourself a straight edge (decent metal ruler) and put it across the top of your head and shine a torch from one side, that will tell if its warped or not. light will come under the ruler if there is a gap. in my oppinion your best off getting the head checked everytime you take a head off (with the intention of putting it back on...), unless you know for sure that its not stuffed. it only takes a very small warp to lose a bit of pressure on the gasket, and pop goes another headgasket! also how great is it that you can pull a k motor head off in like 25mins.... -------------------- ![]() |
Jul 29 2010, 01:16 PM
Post
#5
No i didnt, i used a very sharp chisel and scraped all the crap off myself. Ive done it lasted. So the gasket wouldnt have gone because it overheated cause of no coolant? i only notice pretty late, there was steam coming out the back of the car and then i looked at the temp gauge and its way up there. I just assumed it blew through cause it was roasting?? Thought so. Make sure you get it skimmed then (like $40) before re-assembling this time. It blowing this time was probably still caused by it over heating, but the head not being skimmed made it easy to happen. If the steam was the first thing you noticed then the HG had already blown at that stage. The steam was you coolant water burning in the exhaust after getting into the cylinder. -------------------- I am just a worthless liar, I am just an imbecile. I will only complicate you, trust in me and fall aswell.
Jul 29 2010, 01:27 PM
Post
#6
![]() www.scottmotorsportz.com ![]() Group: Senior Member Posts: 1182 Joined: 28-March 05 From: Nundah Brisbane Member No.: 439 Last Active: 7th September 2010 - 03:12 PM |
The other thing, did you re-torqued the head after you had warmed it up or driven it??
This is a real common problem, people replace the head gasket,torque the head down and then just drive it. You need to heat the engine up and let it sit overnight, then re-torque the head when the engine is stone cold, you'll usually get another 10-20 lb out of the bolts. This is caused by the gasket crashing down, if you hadn't done this your bolts would be 10-20lb looser than what they should be, there for not applying the correct amount of force on to the gasket. -------------------- |
Jul 29 2010, 01:53 PM
Post
#7
did the gasket blow in the same place as last time? also get yourself a straight edge (decent metal ruler) and put it across the top of your head and shine a torch from one side, that will tell if its warped or not. light will come under the ruler if there is a gap. in my oppinion your best off getting the head checked everytime you take a head off (with the intention of putting it back on...), unless you know for sure that its not stuffed. it only takes a very small warp to lose a bit of pressure on the gasket, and pop goes another headgasket! also how great is it that you can pull a k motor head off in like 25mins.... Yep so good, so easy. yeah same spot.So clearly warped then, stuck a rule on it, and i see light lol. dang. Ive got another head here and it seems fine, I think its had some sort of work done the the 4 holes where the gasket would normaly block the water have been blocked with some sort of stuff. Its got a badge which say "GEM ENG VOID IF REMOVED" so I'm guessing they did the work on it, the looking in the end the water ports look pretty clean, not much corrosion at all. Think ill stick that one on and see. |
Jul 29 2010, 01:58 PM
Post
#8
Thought so. Make sure you get it skimmed then (like $40) before re-assembling this time. It blowing this time was probably still caused by it over heating, but the head not being skimmed made it easy to happen. If the steam was the first thing you noticed then the HG had already blown at that stage. The steam was you coolant water burning in the exhaust after getting into the cylinder. Yeh it was more coming from the coolant pissing out of the split hose and going all over the hot engine. But chances are it was burning it to. The other thing, did you re-torqued the head after you had warmed it up or driven it?? This is a real common problem, people replace the head gasket,torque the head down and then just drive it. You need to heat the engine up and let it sit overnight, then re-torque the head when the engine is stone cold, you'll usually get another 10-20 lb out of the bolts. This is caused by the gasket crashing down, if you hadn't done this your bolts would be 10-20lb looser than what they should be, there for not applying the correct amount of force on to the gasket. Thanks for that tip, never even thought of that, Ill be doing that this time round. The second head i have looks to be in better condition all round so i will get that one skimmed and use it. |
Jul 29 2010, 02:00 PM
Post
#9
theres the little badge
![]() and there the head
Jul 29 2010, 03:35 PM
Post
#10
Regular Poster (Caption Editable Now) ![]() ![]() ![]() Group: Regular Member Posts: 83 Joined: 30-May 07 From: Brisbane QLD Northside Member No.: 3647 Last Active: Yesterday, 09:46 PM Real Name: Andrew |
QUOTE used a sharp chisel Hope that was just to pry the old gasket of and not clean the face up ! A gentle "touch" with an angle grinder (wire brush) is the softest way to clean the block n head faces Then sum 320 wet n dry on a FLAT piece of glass/steel/etc pushed flat in one direction will give you a level surface to go by -------------------- 53 Celicas AND counting..
We've more parts than e-bay WORLDWIDE ! - I've CHECKED... ;) Fanatic - WHO'S A FANATIC ? Not us !! It's just a HOBBY :D |
Jul 29 2010, 03:38 PM
Post
#11
the last time i cleaned up a block ready for a head, i spent about an hour with a razor blade and some metho peeling all the crap off the top of the block (mainly remnants of the old gasket).
not sure id be too keen on bringing an angle grinder anywhere near an alloy head though, wanna be a soft wire brush thats for sure:P -------------------- ![]() |
Jul 29 2010, 04:05 PM
Post
#12
Agreed. Angle grinder with a wire brush sounds like good way to do more damage, not fix things.
Jul 29 2010, 04:15 PM
Post
#13
Practice makes perfect and not screwed one up yet !
(YET) Theres lways the next time ! -------------------- 53 Celicas AND counting..
Jul 29 2010, 04:23 PM
Post
#14
well sharp WIDE chisel is esentially the same as a razor. work fairly well.
ANYWAY Its down at Better Sparess in new, there gonna skim it tomoro morning for me :-D ...$44 to get it done, bang on the money if you add gst taz_rx I'm going with the head i had here, I'm hoping the stem seals are still good in it, otherwise i might be blowing a little smoke, anyway its gonna get sold soon when my 2 door is finished. The old one had pretty bad corrosion on the one of the water ports, there pretty almost under the firing ring :-/....surprisingly the gasket held there, but the head was probs warped so i just went in the old spot.
Jul 29 2010, 04:27 PM
Post
#15
![]() Hachi Ni ![]() Group: Donor Posts: 4155 Joined: 19-March 06 From: Ipswich, Qld Member No.: 1373 Last Active: Today, 12:59 PM Real Name: Trev |
Wizzer wheel with a scotch brite pad is the best way to clean up head and block surfaces.
Lo-Fi Version | SEO by MinervaSEO | Time is now: 9th September 2010 - 01:03 PM |
Im4eversmart | ||
