February 6, 200719 yr comment_162867 hey all i got my carby of my 2ltr cortina 2day and jst wondering what i need to put it on my ke55?? thanks Report
February 6, 200719 yr Author comment_162870 Down jetted and a adaptor plate ? i might sound like a bit of a retard but whats down jetted. . i found an adaptor plate on ebay for 40 bucks Report
February 6, 200719 yr comment_162872 It has jets in it now for the 2.0ltr engine you will need smaller jets for a smaller motor. Report
February 6, 200719 yr comment_162873 i might sound like a bit of a retard but whats down jetted. . i found an adaptor plate on ebay for 40 bucks it means that it needs smaller jets so that it dosent drown in fuel as a 2L requires more fuel than a 1.3L. you can't just wack it on and it will run unfortuneatly, but it isnt a big deal to get it changed.. its also webber.. Edited February 6, 200719 yr by tas_ae71 Report
February 6, 200719 yr comment_162935 Ok I found it very hard to find any information of this when I put the weber on my 4K everyone had an opinion but no one had done it or was willing to pass on information so I will post my jet sizes to give you a start point. 1. Rebuild the Carb as a minimum 2. The jets are as follows: Primary Secondary Idle 50 55 Main 125 135 Air 160 165 That is just a start point for you but I find they are working very well on mine with no flat spot off idle or anything. It pulls clean all the way to readline. Make sure that you advance the timing on the dizzy or the car will bog down when you floor it because of the extra fuel. Cheers Paul it means that it needs smaller jets so that it dosent drown in fuel as a 2L requires more fuel than a 1.3L. you can't just wack it on and it will run unfortuneatly, but it isnt a big deal to get it changed.. its also webber.. Report
February 7, 200719 yr comment_162986 it means that it needs smaller jets so that it dosent drown in fuel as a 2L requires more fuel than a 1.3L. you can't just wack it on and it will run unfortuneatly, but it isnt a big deal to get it changed.. its also webber.. well it doesnt actually need to be jetted down as it will run more than allright but it ussaly helps, it will run well but can sometimes be a bastard to drive oh and WEBER is spelt W E B E R, only one B james Edited February 7, 200719 yr by jamesrolla Report
February 7, 200719 yr Author comment_163039 well it doesnt actually need to be jetted down as it will run more than allright but it ussaly helps, it will run well but can sometimes be a bastard to drive oh and WEBER is spelt W E B E R, only one B james hey so it doesnt really need 2 be down jetted. . and as for the weber e bay should have some hey? Report
February 7, 200719 yr comment_163043 yeah you could get away with it but it would probably be better to jet it down, yeah you should be able to pick up one pretty cheap of ebay if you look around a bit, thats were i got mine from, i paid $80 with a ramflo filter and i had to buy an adaptor plate aswell james Report
February 8, 200719 yr Author comment_163225 yeah you could get away with it but it would probably be better to jet it down, yeah you should be able to pick up one pretty cheap of ebay if you look around a bit, thats were i got mine from, i paid $80 with a ramflo filter and i had to buy an adaptor plate aswell james would you be able to send me a picture of ur engine setup so i hvae an idea of the weber and stuff? Report
February 8, 200719 yr comment_163238 [/center] Here is what Ford used on their 1300gt -1600gt kent x.flows 32 dual barrel webers. 1300 1600 primary secondary primary secondary venturi diameter 23 24 26 27 aux vent dia 4.5 4.5 main jet 125 115 150 155 air correction jet 135 160 140 160 emolusion tube f6 f6 slow run pet. jet 50 45 slow run air jet 185 100 180 70 upper progression hole 70to 120 lower p h 110to 120 100to 120 slow run vol contr port 85 100 70 120 full load enritchment jet 85 100 f l air bleed 100 f l mixture jet 100 110 accelerator pump jet 60 65 a p back bleed 40 needle valve 2.0mm float level 7-7.5mm 6.25-6.75mm fast idle setting 15-15.5mm 14.25-14-75mm choke plate pull down 5mm c p opening 7.5 to8.5 mm with lever baced off 10 mm idle speed 680 - 720 fast idle 2000 2500 75hp 88hp Both engines had extractors as standard. The engines are comparable to 4k-5k in cc but had longer duration- higher lift cams than stock- although mild. Hope this is useful to someone as I think it could be a guideline. This didnt turn out like I Typed it , with colums , but with a bit of goodwill I'm sure youll understand. ( When only 2 didgits are used its the same for 1300-1600) Edited February 8, 200719 yr by tojo2 Report
February 9, 200719 yr comment_163346 DR1FT the motor i had my set up on was a dead stock 4k with a standard ke11 exhaust and a hot dog muffler, went pretty well but ended up going to dellorto side draught, i also ran a ram flo filter on the weber, but i ahvnt got any pics of it sorry, was before my digital camera the difference with the kent engine carbys was that they were a 32/32 carby not a 32/36 like you will commonly find on 2 litre cortinas or escorts, Report
