Leaderboard
Popular Content
Showing content with the highest reputation on 08/09/19 in all areas
  1. Man that really sucks! Such a pita, really hope to see it all sorted soon.
  2. Did you pull the distributor? Could have inserted it 180* off, or plug wires switched? Pull the spark plug on number 1 and verify that the cylinder is coming up on the compression stroke, when the rotor is pointing to the number 1 terminal on the cap. Davew7
  3. Name: Gretar Karlsson Car: Toyota Corolla KE70 1980 Motor & Driveline: 2jz with borg warner s360 @1.5bar BMW zf 6 speed gearbox, custom flywheel and clutch Hilux rear diff with 3.58 gears welded Suspension & Brakes: S13 suspension, brakes and modified knuckles up front with custom made control arms Hilux front discs at the rear modified to fit with vw rear brake calipers Hydraulic handbrake with front s13 calipers at the rear, works great. Wheels/Tyres: 15x8 up front with 195-45/15 hankook 15x10 with whatever tyres I have at the moment Interior: Full roll cage Sparco bucket seats, 6 pt harness original dashboard, everything else stripped Custom made shifter assembly Custom made hydraulic handbrake to match the shifter Body: Wide fenders custom hood scoop Build thread: http://www.rollaclub.com/board/topic/65915-ke70-corolla-volvo-b230fk-now-with-2jz/
