Hi James,
Welcome aboard ! Are you looking for a mechanical pump to replace the OEM one one the front LHS of the engine, or are you toying with possibly, switching over to an electric pump, which has some advantages, & disadvantages ?
The original OEM pumps were very reliable, but asked to suck fuel from a long way back. I once had a mechanical pump that would not deliver. After trying two other pumps, with the same results, I came to the conclusion, that my issue was not the pump at all. Issue was a not perfect seal in the fuel line, that was almost undetectable, but pushed the pump beyond its limits. Only found it by running a long piece of plastic hose from the tank to the pump input. It worked perfectly, so hence I went looking for the point, where it was sucking in air.
It you go electric, & mount the pump in the rear of the car, this has the advantage, that the suction line is short, & the bulk of the fuel line from the back of the car, to the carby inlet, is under pressure, not vacuum. However, the disadvantage is, that you must add some safety features to ensure the pump is powered down, if the car is involved in an accident.
Lets know your thoughts.
Cheers
Banjo
