Leaderboard
Popular Content
Showing content with the highest reputation on 07/18/23 in all areas
  1. The running out of fuel, when there is still fuel in the tank, is suggesting to me; that there is a crack or break in the pickup pipe, between the top of the fuel tank, & the bottom pick up point. Once the fuel gets down a bit, the break in the pipe, partway down, gets exposed, & sucks in air. I'm afraid, it's time for the tank to come out, for a complete inspection & clean. You cannot do any thing inside the tank, or even remove the pick up assembly; unless the tank is removed. While it is out, make sure you check the fuel sender unit. Cheers Banjo
  2. So now you know the issue was your carby get yourself a carby kit and rebuild it then you will have the original on and that should make all your idle adjustments easier to perform. A kit costs about $80. You need a clean workspace and a couple of hours and it will be done. I rebuilt the carby on my daughters 4k with zero experience I learned as I went along. It was very satisfying when i reinstalled it on the engine and it fired up first go and idled perfectly. Its been going ever since. Cheers G
