ROLLA FOR L1FE
    32
Everything posted by ROLLA FOR L1FE
  1. muscles matee
  2. lol race car mate ;)
  3. ha yeah well if i get cort i get a 6 or 12 month suspension and a $500 fine..
  4. Hey all can sombody please tell the the throat sizes for a 3k carby? i have to good carbys and the pri is 21 on each of them but then sec had a 24 and the other a 25? I'm just wondering is 3k carbys came out with throat size 25? i have searched but c**t find what I'm after. Cheers
  5. yeah cheers. seemed to be the oil pump. around 40-45psi (4000-8000rpm) and 20psi at 2000rpm ;)
  6. datto A12 and rolla 3K have very similer horsepower
  7. bend ur struts would be the cheapest ;)
  8. mine was actually a datto 1200 not a ke20,, but it seemed to fit in easy. all i done to hold it in was cable tie it in. was only on a trash car tho.
  9. why not go to the wreckers and get and old vs/vn radiator for 20 bucks or so and wash it out urself? i done that on my ke20 and worked good.
  10. i got a 3k cam threw waggot cams for 170
  11. allright so just put it all back in and is around 60psi cold at around 2000rpm.. can't run it for to long as its got no exhaust, can someone tell me if 60psi is good? what do urs run at
  12. ahhk bort some of that oil yesturday. oil pump came from auto and wrong onee :I
  13. nah its not conneted it would be coming on thought.. orded a new oil pump today and put new crank bearings in. lets see how it goes i will be putting it in saturday morning and getting a new exhaust made up monday.
  14. speco meter..
  15. yeah could be anything. the motors not here so can't really see those things. will be here staturday. what is ur presser at idle and high revs? in psi
  16. I'm not to sure. what do you meen by shimming the bypass spring? i no what it is don't get what u meen by shimming haha
  17. i have really low oil pressure in my 3k.. when at idle its about 5, and at high revs 6000rpm+ its about 20-30. we have tried 3 types of oils in it. 25-50w, 10-14w, and sunthetic? or somnthing like that. motors only about 1 month old and around 2 hours running time. its just got pulled down and the bearings are fine. please help cheers
  18. you can get 2 sizes of rocker gear. one being taller then the other.
  19. venice ;)
  20. Do you have another set of rocker gear that you can try? and pushrods?
  21. yes it does.
