sharpshane
    111
Everything posted by sharpshane
  1. So with the new flasher can, I can just bypass the existing flasher or use in series?
  2. So I really like this style thing under the grille. Maybe a deflector of something. What I have not mine just example. The one on there is real flimsy and all bent so i like the other one because it forms to the fenders well and I can do the mesh and it will look B/A. Thanks!
  3. So I bought some amber LED strips slapped them to a piece of anodized aluminum and was going to mount them on my grille. Just to make sure I hooked them up and they don't work. They work with only the turn signals but I can't get them to work with the turn signals and the park lamps on. I saw some other forums about putting diodes and resitors in but I am kinda lost on this one. Any help out there? I will post vid and pics when I'm done!
  4. running a stock 2tc with weber carb. Thinking of going with the dual weber's. I was told if I do that I should get a bigger cam to get the benfits from it. re-do the head all set up for it too.
  5. brakeworld.com check out a 1978 corolla and you'll see em. If there bogus then I'll be sendin them right back. Yes I am asking for steel braided brakes HOSES. I'll check out HEL Thanks to all! I'll send pics of course.
  6. installed new grille today, ordered new slotted and drilled brakes
  7. I have decided to order some 'disc italia' slotted and drilled rotors for the front along with titanium kevlar pads. Got a new master cylinder as mine is leaking. I'll show pics of the process of course. I am looking for steel brakes hoses for the car but can't seem to find the measurments anywhere. Anyone want to help on this one? :greenbounce: I plan to drain and put DOT 4 in the whole system.
  8. where can i find a supercharger for zippy? I'm jealous as all hell :worship:
  9. hey what size tires ya got there on the front? and are those 14" rims?
  10. its going to be a beauty when your done bro. i just got one too. what size are those tires if u don't mind checking it out for me.
  11. So I have some sumitomo 215 50 r13's. They are pretty fat and sweet. Got em shaved and heat cycled for track. I can't seem to find the same size any where. Any suggestions? :hmm:
  12. my car does the diesel out too. Ill try that upper cylinder cleaner
  13. So I've seen a lot of pix with MSD style coils in em but looks like stock dizzy. What's the advantage of getting the msd pack and what else do I need to put in for it?
  14. paradiseracing.com makes a kit too.
  15. Constant whine when accelerating, stops when I'm off the gas. It's a little better now that i changed the diff oil but still noisy. Also the gear box seams to be whiny as well same thing at accel.
  16. yep replaced the alt. then had to find a wire that would hook up from 'ignition on' so the regulator would turn on. now everthin is chargin :y:
  17. installing energy suspension bushings this weekend
    1. sharpshane
      sharpshane
      turns out the kit was for a civic and none fit mine. so i had to order them. selling the civic kit for $160
    2. sharpshane
      sharpshane
      sold! woo hoo $95.00 for me
  18. changed diff fluid yesterday,
  19. oh ya, i looked into it, lots of $$$$ needed and mods, i think ill stick with the 2 tc for now. :blush:
  20. I have a 2tc with a t50 and the diff is locked. Makes a lot of noise about 60-65 mph. I do a lot of driving with this car now. Potential damage if I keep it locked? Should I check the gear ratio or get a new diff? I was thinking of putting a different rear end together with disc brakes and maybe something a little wider as well. Add some fender flares. Any thoughts on that? Existing threads?
  21. hmm, maybe stay with the 2tc and just put some dual carbs
  22. So I'm thinking of buying a 3tc and setting up EFI and turbo.It's going into my TE31, 78 5 speed with a T50 trans. Anyone done this? Pics? Problems? Awesomeness?
  23. I'm thinking a 3tc with EFI and Turbo.
  24. I'm in San Clemente, CA. Workin on gettin the pix uploaded
  25. Did you ever get this fixed? I'm having issues with mine as well. The charge light is on and the battery doesn't charge.
