Ke70 Rear Spoiler
When you find them, I will have one too for my T18
Distributor Conversion. Points Type -> Electronic
Put one of these in a few weeks ago, works great, buy it from US ebay and it comes out of England Toyota Corolla AccuSpark Electronic ignition Kit for Nippon Denso 1.1/ 1.2 1966-1977 ,1.3 1978-1983,1.6 1.7 and 1.8 1970 -1981 The AccuSpark™ electronic ignition module completely replaces the points and condenser with a modern reliable ignition system The kit come complete and ready fit with no other parts required some cars may require 1 wire to be extended We have fitted dozens of units in our own workshop and these give excellent all round performance with notable gains The Hall effect trigger and module give better spark voltage improving starting , tick over , and MPG . This is a good as other systems costing 3 times the price
- Te72 Liftback.
De Ja Vu
I would like an answer to your problem too before I start buying bits for my 5K rebuild and modifications.
Question For The Panel Beaters
The reason I asked about paint is that you need good paint for the glue method to stick. I have just bought this kit on ebay and it is great..cannot believe how well it works, http://www.ebay.com.au/itm/DIY-Car-Repairing-Tools-Car-Damage-Removal-Tool-Bodywork-Panel-Dent-Puller-Tool-/271072264603?pt=AU_Car_Parts_Accessories&hash=item3f1d2a819b#ht_2178wt_906
There are a number of ways, the easiest is to use an attachment that goes onto the MIG that welds a special puller that you break off after using a slide hammer. I use a very small hole and a screw that allows you to pull out the dint then MIG the hole up. If the paint is still good you can try one of those cheap glue gun dint removers that you can get on ebay but they only work on very shallow dints,
jzsupra
