High-Roller
    18
About High-Roller
  • Birthday 10/09/1990
  • Real Name
    Dylan
High-Roller's Achievements
  1. Go for a 20v 4age black top ;) would be my choice if i had a ke30 (: or a 13b
  2. Weight i am not really fused, would prefure it not to be to heavy, disks would be good... want to keep the 4/144.3 Stud pattern, and just a standard lsd i guess? not much of a diff guy, only know a little about them :)
  3. oh... fair enough what diff would you recommend?
  4. mind telling me what IRS is? ha, :|
  5. G'day Blokes... just want to know what I can replace my standard ke30 diff with? at the moment it has a stock 4K and 4 Speed but I want to try do SR conversion later on in its life (just gathering knowledge and parts now) My build that I might be thinking of doing is a Stock SR20DET (i will slowly build on the engine over time but not much just a clean safe street built SR) With a 5 Speed, custom tail shaft, R31 diff 4.11, with all upgraded breaks and suspension But I have heard the r31 diffs can be "Loud"... I am looking at a R33 diff but is this the case also for a r33 diff? are they "Loud" can a R33 diff even work in a ke30? I am not sure as to compatibility with diffs or trans.. so maybe if someone could give me a quick list? cheers. :)
  6. Yeah nah man, they make it look tough "IMO" should make it real aussie street put a set of Centerline convos ahhaaha! nah man good luck with everything this build is sweet, don't see to meany ke11 build's :)
  7. Did you change the stud pattern? to 5x114.3?:)
  8. Where did you get though's black "steelies" on the back of the pano from? & looking neat mate keep it up :)
  9. Where did you get though's "steelies" on your ke? !!! i want some :D
  10. Would be good to see this get done, good luck mate. she'll go like a rocket.
  11. Hey maan sick build! I'm following this for sure can't wait to see what its like ! been a howl year since we last seen this thing
  12. ah sheeeeeeeeeeeeeeeeeeeeeeeet, its already be done you can delete this if you like
  13. Hey Guys, I want to make this thread to talk about 4K builds! Everyone post your *K motors and what you have running & even post ideas, people want to know what the K motors love! Even I want to know.... personally i don't know much about carb motors nor the K series motor, so if you guys were to explain how you think to make Hp 4k's What I would think you would do is simple. Port & polish the head Aggressive cam profile 7k crank bore out to fit 5k pistons have a fiddle with the carburetor (Fatten up the mix) High flow extractors and exhaust Port intake What's your idea? Cheers Dylan
  14. thanks mate helped me out heaps.
  15. Oh Thanks, what size tyre is that too?
