18 -
Everything posted by High-Roller
Weight i am not really fused, would prefure it not to be to heavy, disks would be good... want to keep the 4/144.3 Stud pattern, and just a standard lsd i guess? not much of a diff guy, only know a little about them :)
oh... fair enough what diff would you recommend?
mind telling me what IRS is? ha, :|
G'day Blokes... just want to know what I can replace my standard ke30 diff with? at the moment it has a stock 4K and 4 Speed but I want to try do SR conversion later on in its life (just gathering knowledge and parts now) My build that I might be thinking of doing is a Stock SR20DET (i will slowly build on the engine over time but not much just a clean safe street built SR) With a 5 Speed, custom tail shaft, R31 diff 4.11, with all upgraded breaks and suspension But I have heard the r31 diffs can be "Loud"... I am looking at a R33 diff but is this the case also for a r33 diff? are they "Loud" can a R33 diff even work in a ke30? I am not sure as to compatibility with diffs or trans.. so maybe if someone could give me a quick list? cheers. :)
Yeah nah man, they make it look tough "IMO" should make it real aussie street put a set of Centerline convos ahhaaha! nah man good luck with everything this build is sweet, don't see to meany ke11 build's :)
Did you change the stud pattern? to 5x114.3?:)
Where did you get though's black "steelies" on the back of the pano from? & looking neat mate keep it up :)
Where did you get though's "steelies" on your ke? !!! i want some :D
Would be good to see this get done, good luck mate. she'll go like a rocket.
Hey maan sick build! I'm following this for sure can't wait to see what its like ! been a howl year since we last seen this thing
ah sheeeeeeeeeeeeeeeeeeeeeeeet, its already be done you can delete this if you like
- 2 replies
- 4K
- high performancem
- (and 4 more)
Hey Guys, I want to make this thread to talk about 4K builds! Everyone post your *K motors and what you have running & even post ideas, people want to know what the K motors love! Even I want to know.... personally i don't know much about carb motors nor the K series motor, so if you guys were to explain how you think to make Hp 4k's What I would think you would do is simple. Port & polish the head Aggressive cam profile 7k crank bore out to fit 5k pistons have a fiddle with the carburetor (Fatten up the mix) High flow extractors and exhaust Port intake What's your idea? Cheers Dylan
- 2 replies
- 4K
- high performancem
- (and 4 more)
thanks mate helped me out heaps.
Oh Thanks, what size tyre is that too?
would i have to cut them? and if so will that make the car illegal? or would i have to roll them? or i could cut them and put a fender type side guard on it?
on the stock rims? i need to know if 15x8 -25 will fit and what tyre would fit on them rims?
Hey Guys & Girls Just a quick question, what is the size of a stock ke30 rim? EG, 13x5 +15 and what size tyre because i am looking for a set of 15x8 - 25 offset and i am not sure if they will fit, nor what tyre i will need Please help
