Everything posted by bridge_86
Rough Idle 4K-C (Ke36)
I've put a carby kit through it this helped heaps. followed but replacing ALL the vac lines and fuel lines. now all thats left is the fuel pump coming tomorrow the diaphram was cracked and the pumps leaking from from underneath. so heres hoping when it goes in she'll run alright then i can focus on the rest of the car. its been a longer job than normal because I've just moved (don't GET CARBY CLEANER IN YOU EYE IT BURNS. and red eyes for 2 days) (note: if someone else needs replace the vacuum hoses buy about 3 meters, I brought 1.5m turns out not enough if your doing the whole lot) total cost of parts vac hose, fuel hose, carb kit, (NEW)fuel pump and carb cleaner just over $100
- Rough Idle 4K-C (Ke36)
hey all just got myself a ke36 wagon. was going to be a part car for my ke55 coupe but it's too good to part so fixing it instead. anyway to the issue. idles rough without choke pulled the charge light stays on and when I put my foot on the accelerator (heavier than feathering or choke) it'll cut out. I've checked the dizzy had a little bit of shit on the points once cleaned the car starts a lot easier. but the idle is no good. would running rich cause this (smells like it)? here they are.
- (Ke55) Reverse Light Wire
Ke55 4Spd Box Loom
nope manual k50. still can't find it. and I'm going nuts i have a pic of my engine bay here, just less clean http://www.rollaclub.com/board/topic/67706-ke55-reverse-light-wire/
I have a ke55 coupe (square headlight) with a 4k-c and k50 was a junior rally now my project to get back on road. I'm keeping the 4k-c and k50 for now (stupid saving for house, i want car parts) under the bonnet I can not find the the reverse light wires. I can see the reverse switch wires coming out of the box its the other side (wiring loom side) i can't seem to find. ive looked under the booster, under the car and am about to check under the carpet in the car (its dirty anyway) this has been the bane of my existence.for about 2 weeks can some one post a pic of what and where its supposed to be. I really think i may be missing a wire or a length of. thanks.
Ke55 4Spd Box Loom
i can't seem to find the wires in my engine bay. I've looked all along the firewall and can't find the wires from the loom to hook up to the reverse switch can some one point it out for me??
