corollaTE27Fan
    64
corollaTE27Fan last won the day on May 28 2020
corollaTE27Fan had the most liked content!
  • Location
    UK
  • Real Name
    Keith
Recent Profile Visitors
2299041 profile views
corollaTE27Fan's Achievements
  • First Post Rare
  • Collaborator Rare
  • Conversation Starter Rare
  • Week One Done Rare
  • One Month Later Rare
Recent Badges
  1. Thought I would ressurect this post as after a house move I am back working on my 4AGE into KE20 conversion. I have a questions if anyone can help. Firstly I am running a twin carb fuelling setup with distributer less ignition controlled by a trigger wheel tps, coil pack and Megajolt ECU for ignition only no complicated MAF gear. I have a kit that is supplied by Trigger Wheels here in the UK, but unfortunately information on how to fit is limited in the UK. I know how the kit works and the basics of what goes where and the wiring but lack knowledge of the best way to position the TPS so that it sits correctly in front of the trigger wheel. Where would be the most sensible location for the coil pack location, also have a support bracket for this but no info on the location. I also have a bracket for the TPS. Will post some photos of the brackets shortly.
  2. Well, not much progress since last August due to loads of family stuff that has been going on. i did find that my KE20 propshaft was not considered to be strong enough and the T50 output shaft spline configuration is different to that of the T40 that i took out. I now have the correct yolk for the output shaft to be fitted to the new propshaft that i am having built. Need a few more odds an ends but hoping to get it running by the end of this year, hopefully not famous last words.
  3. Apologies my first ref to "diff" should read "Prop"
  4. Been knocking around the Forum for a few years now since joining to discuss my KE20 4AGE engine version that some of the older members may remember. Well believe it or not I eventually had a fast road spec engine built here in the UK by Macer Sports. With the engine I swapped out the 4 speed gearbox for a late T50 5 speed. Having great problems here in the UK sourcing a propshaft sleeve to fit the T50 output shaft. I am now looking farther afield as i need 21/22 spline fitting as my T40 had a 19/20 spline output shaft. Does anyone have a spare or know where I can source this part? Thanks in advance folks. PS here are a few pics of my progress after about 5 years!
  5. My rebuilt 4AGE is going to be ready in a couple of months to go in my KE20 and I need to start thinking about headers and an exhaust. Looking for ideas of what would fit off the shelf for headers down to the collector. Engine is not in car but need to get headers sorted at least if feasible. Anyone able to offer any suggestions?
  6. I caught the top of a dropped bollard that had not been lowered properly on a private road going to a car club meeting. It seems to have clipped the front and pull it back, though on the face of it looks more like superficial damage than 'structural'. It seems that the metal is really quite flimsy and I was not going fast at the time. Car still drives fine with no pulling when braking or any apparent steering issues. My car is in near 'mint' condition and I would like to keep it as original as possible. I have sourced a chassis complete with running gear intact but the buyer is asking in excess of £1500 which is silly money. I hope to get my newly built 4AGE fitted later in the year so may try and deal with it then when the engines out. I'll post a picture when I next get it up on a lift.
  7. Looking for a front suspension cross member to allow me to repair some damage to my current one. Anyone have one that they would be willing to sell and ship to the UK? Cheers
  8. I dropped mine 1.5 inches and used Mk1 AW11 MR2 strut inserts (kyb 363046) and Mk2 2 Ford Escort rear shocks (kyb 343020). I have purpose made 1.5 inch lowering springs that fit the existing struts and am using 1.5 inch lowering blocks on the rear. Only issue i had wxs the need to bush the strut insert tops by about 15mm to stop them knocking. I am running 13 inch alloys with standard fitment pcd with 0 offsett and 185 60 13 tyres with no mods to bodywork and handling and tyre wear is perfect. Hope this helps.
  9. What a great looking car! I am in the UK doing much the same with my KE20 and I have decided to go for a mildly tuned small port 4AGE standard engine swap which will give me around 160BHP. For a car weighing only 800 kilos that plenty of power in terms of a power to weight ratio. Be interested to hear how you get on and the mods you decide to go for.
  10. Thanks for the tips chaps. I have 185 60 13's on my current 6j alloys and even with the car being lowered 1.5 inches they run fine with no scrubbing around the arches. I can see that if i wenr to a 7j wheel i would probably get srubbing on the arches. I may just stick to what I have, though I would really like to get some classic jap alloys but they all seem to start at 7J.
  11. Pete, by "too big" do you mean too wide, as the diameter is only 13"? I am trying to achieve the appearance of the orange car in altezzaclub's reply above in my KE20. Maybe I just need to stick with my current 5J wheels and try some spacers for a similar effect and see if the tyres rub, though I did not really want to use spacers.
  12. I have aquired some 7J 13 inch alloys that have the right offset but project about 1.5 inches beyond the standard arches. I want the extra width but did not want to have to cut the arches and was hoping to use some 1.5 inch metal fender flares to cover the tyre projection, similar to the ZTE look. The car is lowered 1.5 inches front and rear. The question is can I use the wheels without cutting the arches and if so what width and profile tyres would work?
  13. If I remember correctly the rear shocks were from KYB and the part number was 343020 and the front strut shock inserts were all so KYB and the part number was 363046. The front strut shock inserts were 38mm diameter but about 20mm too short hence the need for some packing. No pics though, wish I had taken some now to share.
  14. Well, after almost 3 years faffing around I finally have the suspension sorted - if anyone is interested, for my 1974 KE20 coupe (Jap spec), MR2 Mk1 strut inserts worked with a turned brass spacer the same size as a 22mm copper compression fitting nut in the front and Mk2 Escort rear shocks on the rear. Kept everything else standard with 1.5 inch lowering blocks. Currently running some period 13 inch 6J alloys with correct 110 bolt pattern and not to fat tyres with no issues with tyres protruding beyond or rubbing on arches. Now looking to change front hubs and rear drums and drive shafts to get a better choice of Jap period wheels, hoping my KE30 shortened drive shafts in my KE20 axle with KE30 drums and back plates will work. Also hoping that the KP60/61 front hubs that I have will fit my standard KE20 front struts. Also have a mildly tuned small port 4AGE being built for me here in the UK which should deliver about 180BHP which is more than enough for my needs as it will be used just as a road car which should fit nicely in front of my T50 5-speed gearbox when I can find the parts to re-condition it! Photos to follow.
