RussRolla
    21
    2
Everything posted by RussRolla
  1. Hi Banjo, I have old school lock down pins very hard to find. Russ rolla
  2. This is my ride, have owned since 2009. I get I lots of thumps up when I drive her...
  3. I think I may have discovered the brake Caliper used on my 82 ke70. 1982 Ford falcon. I will do some more research and get back to everyone. The rubber kit looks the same too.
  4. Hi Banjo, I'm thinking about selling my ke70 I have been offered $5000 from a bloke in Brisbane that saw the Rolla and left a note on it.? What do you think about price. The old girl needs paint. Has done 280k. Has been well maintained.
  5. Welcome Guvna, Russrolla.. 😎
  6. Hi Rolla club, just to let you all know this did not fit. My car is and ke70 XX with girlock brakes built in Australia. The new pistons are about 2 - 3mm to big. The kit I found on megazip.net is Search Toyota part by OEM part numbers: 04479-12060,New genuine parts Cylinder Kit, Disc Brake, Front, Toyota, 04479-12060 is used for Car & Auto: Toyota COROLLA, Toyota SPRINTER/ CARIB/ TRUENO.
  7. Hay Banjo, original paint, it needs new paint tho 40yrs takes its toll. I will take pic of inside next time for you too. But for now engine bay. Going to put battery in boot soon too. For the last 13 or so yrs I avoid driving in the rain or on wet roads. I Polished the body and fish oil under body every 12months. Always something to do... Russrolla
  8. Wow, that's awesome...
  9. Cowrolla
  10. Thanks Banjo, I haven't had time to today will check it out tomorrow and let you know. Also this is a pic of my girl. I have owned her for about 13yrs now.Thanks for all your help Banjo. Russrolla.
  11. I havent been able to buy calipers or repair kit for them online in Australia.do you know any were in Australia to buy I'm about to buy from eBay in Thailand. Has a repair with pistons for $70us about $100 aussie...
  12. Hi rollaclub, my front brake on my ke70 has worn flat think the piston is not backing off does any body know if or where I can buy a kit to repair or replace the caliper they are girlock brakes at the moment...thanks Russrolla....
  13. Thank you altezzclub, I have removed and replaced the gasket now. Thanks for the advice I didn't remove the sump it doesn't come out as you said was hoping to paint it at same time. Maybe in 20 odd years I will remove the 4k engine for electric motor. Thanks again for the advice. Russrolla...
  14. I have a single Webber 40dcoe, and I love it. Sounds great. Looks great. Hard to find mechanic to tune them well. Get yourself a book on tuning it. The Webber side draught uses different jetts and throat sizes you match your engine size and power to the webber
  15. Hi everybody, just a question for removing/replace oil pan gasket in 4k ke70 can I remove the oil pan if engine is still in the car how hard is remove/replace gasket? Thanks..
  16. Thanks 7000rpm
  17. Hi all in the Rolla club I was wanting to no what size for a single 40dcoe on 4k engine with extractors in my 82ke70 the engine in from an 83modelke70 1=main jet 2=pump jet 3=idle jet 4=venturi size Thanks
  18. Sorry tried to remove too ? Topic
  19. Hi Rolla club just want to no what size 1=main jet 2=idle jet 3=pump jet 4=venturi size On my webber 40dcoe side drift Stock motor with extractors thanks rolla club
  20. I had the same thing in my 82ke70 it's not the lights it the clicker behind the steering wheel need a good clean
  21. So i have not been able to find emission parts did find on google image of the emission lines i have ordered a size draft webber 40mm with manifold for $800 from procarb that will get the old girl moving again sweet
  22. hi everybody I have a 1982 ke70 with aisan carburetor I m having trouble with can't seem to get the lines wright for emission and vacuum hose can anybody tell me to where I can get emission parts from or can I just use lines on vacuum do I need all parts to make it work please help this have been a problem for a long time now pls help pic would be great thanks
