dingo ke55 5k
    34
Everything posted by dingo ke55 5k
  1. wire brush works ok to a point, if the bolts are rusty or damaged i find a thread file exelent to clean and retreive threads. These files are square in shape and have all your usual thread pitchs 4 per side hench why they are square, cheaper and more practical than buying heaps of dies
  2. why use a seat belt? when the dash and steering wheel can hold you in place :jamie:
  3. Ive been running my 4k and 5k using unleaded with no problems. Remember though if you have a hotty best to use premium with the higher octane, but with petrol prices at the moment :hug: best stick with regular, ether way it wont hurt them.
  4. bike prices are very strange and hard to understand at times. In S.A. 250cc motorcycles bring in good money due to the max size on your Ls and Rs being 250cc try $4500-$8000 for any 250 road bike from 1989 onwards wheras you could get a 1990-95 gsxR 750cc for $3500-$5000 its a joke :hug:
  5. Street Machine have come forward with the times over the past 5 years, they don't just do v8 stuff anymore they cover almost the entire hot car scene. I have every single issue from numero uno to present day, has taken 8 years to find every issue
  6. Yes rust was a very big issue with the AU, mainly the lower section of the A pillar would rust right out causing the lower door hinge to come adrift. Not good. :y:
  7. The Falcon SOHC 6 have the same problem the alloy heads heat and cool diffrently to the cast iron block causing distortion, allowing the head gasket to blow out. A sure tell tale sign is coolant dripping between the block and the head very common problem. That aside the M series as Super Jamie pointed out aint bad as long as they are maintained. Getting good power out of them isnt hard either :D
  8. When i do the pre delivery inspections on the new Fords at work ive found that the BA Falcons build quality is average. The F250s from the good ole U.S.of A on the other hand aint that bad just the interiors a bit tacky. Quite a thumper of a vehicle the big block 7.3 litre turbo diesel has neck snapping torque and impressive power always put a smile on my face when i road test them :D
  9. No i don't think being a mechanic takes the fun out of my hobby. It makes you more knowlegable and careful, it makes you hobby even better :jamie:
  10. But for some reason i keep going back :jamie:
  11. I done my apprenticeship with the M.T.A, ive only got one thing to say about a mechanical apprenticeship :jamie: You work your arse off for four years getting all the crap all the qualified mechanics wouldnt touch with a ten foot pole. I'm now fully qualified working at Stillwell Fords. The guys there are great but the wage is shit I'm only on $16 an hour, plus you get dirty and go home stinking. If i could do it all over again i would steer clear of the mechanical trade like the plauge :sad:
  12. Why don't you check your crank to cam timing. The timing belt could of slipped a few teeth
  13. Jeaz South Australia is slack compared to other states by the sound of it.
  14. Its landed :jamie:
  15. The SUs are better? Better hook myself up then :jamie:
  16. Throw your old carby away along with the SUs and get yourself a 32-36 weber off a Escort / Cortina. A 7K should have no problems with this carb :jamie:
  17. I went down to motor reg today to get my motorbike licence anyway i found out that i was disqulified for 6 months. I should of stopped driving in May. Wheres the notification, am i suposed to be physic. I deal with motor reg fairly regulary i would of thought i would of found out earlier or at least a letter telling me i was banned from driving. :y:
  18. Hey guys. I was wondering if any one can help me. My headlights and high beam stopped working, the parkers still work though. Ive checked fuses wiring and the globes ,all ok. Is there a relay that powers the headlights? I'm guessing there is but i can't locate it. Any help would be appriacited. Thanks fellow Rolla Heads. Dingo.
  19. Have you ever seen that alfoil sticky tape? My mate years ago wrapped his whole moutain bike in it coz he thought it looked cool! :y: =)
  20. Like Nick said get a pressure regulator then you can get one of those small fuel line pressure gauges ;) fully sic mate
  21. Used to have a Charger, man that thing was a thumper i spent big bucks on the drivetrain,it was a 265 running monster tripple 45mm side draught webbers,11-1 comp ,crow cam with 520'' lift and a massive 302 degrees duration. Ran a 13.8 @ 109 mph. Wish id never sold it, i might get rid of the EL Fairmont and get another one! ;)
  22. Chryslers first real market attempt in Australia was in 1959 when they sold Chrysler Royals, it sold poorly compared to the Holden. In 1962 Chrysler Australia assembled the Plymouth,Valiant 'R' series and just called them Valiants. It floored the competition, The Holden and Ford at the time put out 56 hp and 90hp respectivly, the Valiant put out 145 hp, very good for 1962. Moving up to 1969 Chrysler brought out the VF model it had a squarer body. A two door version was made at the same time looking very similar to the dart. Chrysler pulled the pin in Australia in 1980, Mitsubishi sold the last few Valiant remaining until stocks were exhausted, and that was the end of that
  23. that is some of the best fabrication i have ever seen. The hard work looks like it paid off. Good job :P
  24. yeah its strange i ripped some of the pinion gear and crownwheel teeth off whatta mess :P
  25. Went out on the old rolla cruize in Adelaide on Friday, had a real good time meeting other corolla nuts and flying through the hills, things were going good. That was till i stacked the ke55 into the back of a ke 20, the 55 came off second best. Scratched the 20s bumper while i trashed the lhf of the 55. Pushed the lhf headlight back into the battery, folded the front gaurd back onto itself, smashed the grille and folded the bonnet. sob Later on i was chasing Scott A.K.A PMP020 when i blew the locked diff :P Managed to nurse it home complete with some new strange noises. I replaced the diff today, unfortunatly its not a locker :bash: also panel beated the gaurd and replaced the headlight looks ok, gotta new gaurd just have to colour match it and itll look as good as new. :y: Scott took pics of the mess so hopfully he'll post them up soon. Dingo.
