MattyZ
    360
    2
Everything posted by MattyZ
  1. hey mate, awwwesome rebuild, doing it properly first time I'm doing the same with my ta22, ground up no nut left untouched lol i was hoping ya could answer a few questions did you apply any rust preventative paint or primer on the under body before the tar or did you just apply the tar to the baremetal? how much did it roughly cost to do it? did ya do it with rattle cans or with a spray gun? cheers keep up the orgazmic rebuild matty
  2. so i got it relatively lined up few gaps but nothing that can't be filled, with a sliver of metal. got it tacked now just need to finish the taking then go round till no more gaps use a linishing disk to grind the welds flush, wire wheel brush surrounding area and rest of inner guard and move onto replacing the metal section where the battery tray used to reside.
  3. no picture just code
  4. ok so today ive started to replace the left inner wheel arch, i started by removing the inner arch from my donor celica and cutting away the fat till i was left with what i needed shown below then i cut away the corner which the quarter panel bolts to at the bottom heres the rusted and the repair piece and repair piece held in place heres the nice tiny size hole left in the floor pan and inner gaurd i also have to replace the backing for the corner piece which was not rusted in the repair piece so i just cut it all out into one big section hopefully by the weekend i can have it all tacked up or fully welded in so i can rust prevent it and then wack some Por15 and sound deadner on the interior and exterior of it enjoy
  5. ok so 99% of this has been about my celica and not about my corolla so ill give you a bit more of an idea on what i have planned for it I will be keeping the body how it is just tidy it up, eg. repair the rust around the boot seal and inside the boot the only exterior change i will make is add a pair of chrome rectangle mirrors to the doors and order a white interior venetian blind rolling i might invest in a set of challengers or just run 14inch stock wheels with low profile tyres white walls engine wise, i will either go with a warm 5k duel carbs extractors pistons or a 5kze or te undecided yet. upgrade all the suspension brakes etc AE86 items but over all keep it sleeper but that might be hard with yellow in ya face paint, if it comes to it and its covered in primer patches ill respray it devil yellow and re apply the black pinstripe please let me know your thoughts and ideas on this
  6. Cheers for that
  7. Hey all i was looking on the diff from my ta22 and found these 2 numbers and was wondering what they meant one on the center around the bolt pattern has a stamped E then a bulging 21 picture below and on the center it has on a tag X 21 if anyone can shed some light on these cheers
  8. just tossing up which rims i want to run later on down the track ive narrowed it down to 3.... for now haha Work Kai polished or white Work Equip 03s polished SSR Professor SP1 R Polished or silver Opinions needed personally I'm either leaning towards the Equip 03s or the SSRs more the Equips either one will have mad dish haha
  9. i love this back yard, feel free to come on a road trip and park them in my back yard :P :(
  10. made a little list to get it on its wheels Underneath Finish drop box welding Grind Welds flush on drop box Wire Brush Underneath, front to rear Knock out any dents Fix shifter hole Weld any holes Grind any welds Por15 underneath rust protector and sound deadener. Inner Front Guards Wire brush inner guards Replace Inner L wheel arch Weld up Grind Weld up holes inner guards Grind up holes inner guards Replace front quarter panel bolts bottom Straighten up front panel Por15 rust protector and sound deadener inner guards Front Quarter Panels Wire brush inner front quarter panels Por15 rust protector and sound deadener inner guards Differential Grind and Por15 diff (either RN25, T Series) Struts TA22, or AE86 Grind Powder Coat Steering Rack, Cross member, LCAs & Mounts Grind Powder Coat or paint Brakes Grind callipers (TA22 or AE86) New rotors (TA22 or AE86) New brake pads (TA22 or AE86) Order Suspension Parts Order 7-8kg front springs and rear springs (AJPS, Kingsprings, Pedders) Order suitable shocks for front and rear (KYB/AGX, Koni Order front swaybar (24mm or similar) Order front swaybar bushes (if not in swaybar kit) Order all new front end bushes (pedders or Nolthane) Order rear Panhard rod (AJPS or Whiteline) Order rear bushes Order strut brace (AJPS, CUSCO, Whiteline) Camber tops?? (AJPS, CUSCO) Brake Lines Order new Brake lines Rear Brakes New drum shoes or rotors New drum cylinders or pads Installation of Bushes, Swaybars and Springs Install all new bushes, shocks, springs Engine Bay Grind Fix rust Seam weld Grind welds Smooth Putty Primer Paint Voodoo Blue Install Front End Attach Cross member Attach LCAs Install AE86 or TA22 shocks, springs, tops, rotors, hubs. Attach new brake lines Attach callipers to rotors Install Front Swaybar Install Tension Rods Install Steering Rack Install Back End Install Diff Install 4 link Install shocks Install springs Install Panhard rod Wheels 15” Sigma Turbo Wheels. 14” Chaser Stockies 13” Jelly Bean Mags 14” or 15” White Wall tyres 14” Chrome wheel trims and centre caps Anodised Blue Wheel Nuts. Interior Grind, sand interior Seam weld Cut out and replace rust sections Por15 rust protect interior Dynamat interior Reinstall handbrake. Connect up handbrake Replace Rear Seat Anchors Rear Quarter Panels / Boot Fix rust rear panels Grind boot Por15 rust protect Dynamat soundproof Replace rear parcel shelf Boot and Fuel Tank Setup Paint fuel tank Surge tank and fuel pump set up Make sealed box for both Mount battery box Run battery cables Carpet / Trim boot black carpet still truckloads to go haha
  11. hey mate yeah done some more 80% of engine bay is now bare metal, started degreasing underneath so i can grind that and ive now got a RN25 Hilux diff lined up from a mate so things are slowly coming together. and I'm going to use a camry brake master cylinder from a 03-06 camry heres some photos ill get some more work done on it tonight enjoy let me know ya thoughts :(
  12. cheers heaps, youve been a huge help, and cheers for the master cylinder upgrade advice too
  13. i havent heard of anyone mention the RN25, ive only been told to search for the RN41, and i have access to a 78 hilux getting scraped and just wondering what series diff is in it, if its a RN25 or a RN41 SHIBBY! ill have ma bullet proof celica ass end and then a T series diff and maybe a T50 for my KE70
  14. that is what one would call f@$kin tuffff, now just needs the grunty heart to top it off keep up the sic work
  15. is the diff in a 78 hilux a RN41? and if it is how much would one be worth roughly with a noisy centre? id replace the centre with a g series lsd and use MA70 rear hub carriers, backing plates and brakes and would the brake booster fit a TA22? for an upgrade with the brakes?
  16. try www.classic-celica.com free forum heaps of 2jz into 1st gen celicas on there
  17. ill get ya rollin with the plans haha just some ideas, 1j highmount coilovers booooost and rimz haha keep us updated with what ya doin to it as I'm veeeeeeery interested :)
  18. sweeet that supras niiice too, congrats on the swap now to start makin plans for the supra haha
  19. if ya lookin at keepin the 2t put beefing it up heres a site that has everything pistons rods cams carbys intakes ignition etc http://www.brdracing.com/index.htm
  20. Is the J160 Or W55 around the same lenght as the T50?
  21. cheers for the advice/help cheers for the advice/help
  22. yep sure do have some work ahead, its complete bare shell lol, ive been keeping a close eye on yours for the same reason see if i can pic up any little tricks that youve tried etc my motor will be just a 13t with extractors and single weber nothing special until i find a suitable replacement, I'm hoping mine will turn out alright clean streeter. ill get some pics up tonight.... hopefully
  23. Diff and T50 are in my TA22, will be used as a daily and for a few spirited drives, lookin at a 3SGE with a bit of work done to it, any ideas for box upgrades then, W58?
  24. Little bit of an update sorry no pictures, will try take some tomorrow, ive used a wire brush on the left side of the interior to take it back to bare metal, so i can por 15 rust protect it then wack on some dynamat. also been doin some thinking with engine, thinking a nice warmed over 3SGE, quads, pistons, cams, etc give it a bit of boot. will keep ya all updated. and on another not KE70 is off the road for a bit demisters are up the duff so gettin those fixed Made a list of things to do so i can get the celica sitting on its wheels Finish drop box, (welding, Grinding) Grind Welds flush on drop box Wire Brush Underneath, front to rear Weld any holes Grind any welds Por15 underneath rust protector and sound deadener. Wire brush inner guards Replace Inner L wheel arch Weld up Grind Weld up holes inner guards Grind up holes inner guards Replace front quarter panel bolts bottom Por15 rust protector and sound deadener inner guards Wire brush inner front quarter panels Por15 rust protector and sound deadener inner guards Order 8kg front springs and rear springs Order suitable shocks for front and rear Grind and Por15 diff Order front swaybar Order front swaybar bushes (if not in swaybar kit) Order all new front end bushes (pedders or Order rear Panhard rod Order rear bushes Install all new bushes, shocks, springs, and diff Replace brake rotors, and pads front and rear. Install Rack and all steering components to body Put 14” stockies on painted black, chrome rings and centre caps Grind, sand interior Seam weld Cut out and replace rust sections Por15 rust protect interior Dynamat interior Reinstall handbrake. Connect up handbrake
  25. Hey all just wondering what power outputs have people had going through a T50 and open wheeler T series diff before they ran into issues? or roughly what the limits would be.
