Search the Community
Showing results for tags 'lower control arms'.
  • Search By Tags
    Type tags separated by commas.
  • Search By Author
  • rollaclub.net
    • KE70.com
  • Rollaclub Technical
    • Automotive Discussion
    • General Mechanical
    • Engine Conversions
    • Car Electrical
    • Motorsport
  • Rollaclub Rides
    • Rollaclub Rides
    • Rides - non-Toyota
    • Did it Myself
  • Rollaclub Social
    • Rollaclub Social (Off-Topic)
    • Rollaclub Regional
    • Forum Support
  • Market Place
    • For Sale - Car Parts
    • For Sale - Cars - Toyota ONLY
    • Wanted to Buy
  • Best of Rollaclub
  • TOMsGPTurbo's Blog
  • Slant to Flat Conversion
  • visuli's Ke 20 Blog
  • The Silvia
  • LJMC-KE20's Blog
  • jimmy5det's Blog
  • Chadwick's Blog
  • 77KE30CS' Blog
  • deddy2012's Blog
  • little help please
  • oquinton's Blog
  • balico's Blog
  • KE72 Wagon
  • ke70 coilovers?
  • FAQTMU's Blog
  • rolla_van93's Blog
  • JJke55's Blog
  • Tezza15's Blog
  • nana_car_67's Blog
  • sweetke55's Blog
  • 78KE35
  • respect55's Blog
  • ZacKE70's Blog
  • HaydenRolla's Blog
  • *SErolla's Blog
  • Ke35 Hardtop
  • haydzzz's Blog
  • boomboom4786's Blog
  • rolesy's Blog
  • My38's Blog
  • GJM85's K Motor Blog
  • sharkboi's Blog
  • ke20rolla1971's Blog
  • Selling my rt80 corona
  • Crostek's Blog
  • Tweets ke30
  • SEM600's Blog
  • J-ROD's Blog
  • G0TRIC3?'s Blog
  • appsy's Blog
  • NEED A 22re STARTER MOTOR
  • The Kid's KE15
  • dirtyke29+1=30's Blog
  • rolla76's Blog
  • conmeow's Blog
  • corollninstyle69's Blog
  • Cleighton's T18
  • mazrotor's Blog
  • corolla_ke700's Blog
  • MartyJ's Blog
  • rolla_j's Blog
  • https://game-onlinetvchannel.com/colts-vs-titans/
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
How did you find us?
Real Name
Found 2 results
  1. Hey all, as title states I binned the KE55 and lost the front wheel while cruising and now the front LHS LCA is messed up. Anyone in South Australia have a LCA from a KE30 or 55 I can buy? Or postage to SA 5501? happy to buy a pair if need be. Cheers Ryno.
  2. Hi there, What are the options that we have to upgrade a KE20/25 front suspension. 1. Which crossmembers can we use, KE30 or KE70 or KP61?? 2. What are the shortest LCAs that can be used on a KE20?? Are there any shorter than KE70?? I am busy designing a rack & pinion setup for my car. I have installed a starlet rack in but as it is wider therefore bumpsteer issues Temporary fix - Drop the car as much as possible - Less movement less bumpsteer. Currently drives excellent on flat roads with small bumps. . Out of all the crossmembers I have seen, the ke30 looks the easiest swap. My current track width is R LCA + L LCA + Inter LCA distance = 320mm + 320mm + 493mm = 1133mm If I use a KE30 crossmember with KE70 LCAs 300+300+520 = 1120mm (1.3 cm Narrower) OR If I use a KE30 crossmember with KE30 LCAs 310+310+520 = 1140mm (0.7 cm wider) Would any of these be a better start in rack and pinion conversion??
