Search the Community
Showing results for tags 'master cylinder'.
Hi All, I am having trouble finding an Australian production master cylinder for my KE30, it would seem only the Japanese production cyl's are readily available, same said for the brake booster that seems to be few and far between. Any information on replacements that will bolt up / any information on where I can find a direct replacement is very much appreciated, this is my last step for a rwc. Thanks in advance - Luke
Hi all, I've had to source a brake master cylinder and proportioning valve from the wreckers for my car. The parts are in reasonable condition with a bit of rust on the outside housing, the guy at the wreckers said the car had been sitting for at least a few years. I looked up some parts catalogs and it appears they don't make rebuild kits for it anymore because 1981 was a while ago (its not a corolla). Basically I want to throw these parts on the car but I don't want them seizing up all my brakes. I read you can soak the master cylinder in vinegar, and put it in the dishwasher apparently, don't think the misses is gonna let me do that. If I have some rust inside the piston area is this a reasonable idea to soak it in vinegar for a bit and throw it on the car, or is there any other way I can cheaply and easily do a minor reco. I wouldn't trust myself completely pulling one apart and putting it back together correctly haha. Cheers
I understand drum brake master cylinders have a "residual pressure valve" to keep say 10psi of pressure in the brake lines, as drum brakes require this to compensate for spring return tension. However, when you convert drums to discs, you need to remove this valve, or your new disc brakes stay on when you let go of the pedal. How does this work when you go the other way - putting a disc brake master cylinder on a drum brake car? I see Wilwood sell aftermarket residual pressure valves, is this the only way, or can you install a valve in the new master cylinder? JB1762 (15/16") bolts to KE30 booster. It comes from NE Pajero which had factory discs on the back. I'm also looking at Nissan master cylinders from S13 which had discs. JB1608 (7/8") also bolts to KE30, but comes from from NA Pajero has drums on the back, so no issue there I guess.
Have put ke55 discs into front of my 1971 ke20. Have got no pedal pressure, has to be pumped a few times to firm them up. Its older master cylinder type. Has anyone else done this conversion and had trouble? Ive read it could be my master cylinder being too small for the front calipers. They are girlocks. Any help much appreciated. Cheers.
