November 2, 200620 yr comment_149288 do the cams on 4a's spring off of tdc or do they sit still? the ones one my sisters 1.8 astina did, but my 1g ones didnt wondering if its a size of cam thing, or a 4cyl thing.... and des, setting cam timing is as easy as justin said, just can be good fun gettin the belt on nice, sometimes have to turn the cam wheel a smidge to make the teeth line up with the teeth on the belt :jamie: Report
November 2, 200620 yr Author comment_149291 That picture makes it so much easier to understand. :jamie: Now what timing belt to use? Genuine toyota belt or a repco one, Is there any difference in reliabilty? Report
November 2, 200620 yr comment_149299 I hope that picture & explanation is available in the FAQ. If it isn't, it damn well should be, because it's perfect. Report
November 2, 200620 yr comment_149311 I wouldn't go anything other than genuine Toyota.. Now i have been told that a gates is a genuine Toyota belt just restamped and a dayco is mitsubishi, Anyone confirm this? Report
November 3, 200620 yr comment_149420 Now i have been told that a gates is a genuine Toyota belt just restamped and a dayco is mitsubishi, Anyone confirm this? I can't confirm it, but I wouldn't hesitate running a Gates belt. They make belts (are the leaders I believe?) for Top Fuel superchargers so your pair of camshafts are a walk in the park. Report
