Aftermarket Tacho
hey everyone
i bought an aftermarket 2" tacho to put in my ke70 but i am having a bit of trouble on which wires to connect to what etc
so if anyone has done it before or can just help me this would be much appectiated
cheers
Do a search. There are many threads that have covered this topic already.
don't know about your but mine was
red = ignition switched 12 volts
black = ground
white = 12 volts from your interior light i had mine going to ignition switched 12 volts tho
green = positive or possibly negative on the coil
hope that helps
Green is goes to the negative of the coil.
where is the ground wire?
and mine has an orange wire that goes to battery + where do i connect this up to
thanks for your help
ground is either a black wire or find bare metal on the chassis to connect it to with a screw or bolt
... maybe get it installed at a workshop.
or learn basic electronics, buy some tools and parts then
red = usually positive
black / ground = negative
white = usually lights
green = usually signal
pink = usually memory (not applicable for tacho)
you can spline into an existing power wire or run a new one from battery for power,
but
*you would want the device to turn off when you turn the car off*
so its best to splice into the accessories circuit or any circuit powered from accessories for low current
drawing devices, for larger devices use a relay setup triggered off accessories.
joining methods are:
strip plastic coating, solder, heatshrink.
cut wires, crimps, join crimps.
use wire taps.
use one way insert boxes.
use terminal strips.
use plugs, ie molex etc.
don't cut wires, then twist them together and cover with tape. its wrong in so may ways.
hey check this out:
how to connect wires
also a set of insulating rachet crimpers are far superior to those crap simple ones.
Edited by styler
