February 18, 200719 yr comment_164569 Hey everyone, my car soudns alright drivign around town and stuff, but at 100 on the highway i get a real loud noise, ive been told its wheel bearings, searchedo n ehre and heard wheel bearings or diff. it doesnt seem to fit a bad diff diagnosis. it does sound more like noise from the wheels rolling along, is it due to bad insulation of the cars not blocking out enough noise, or just sum stuffed wheel bearings. autobarn said 40bux a set for front and rear, would that be all id have to buy? or will i need seals and grease and stuff? I'm not to sure what a wheel bearing looks like. Report
February 18, 200719 yr comment_164577 If you're not sure what a wheel bearing looks like......its probably better you take it to a mechanic. To change the back ones over you will need to get the bearings pressed on anyway. Report
February 18, 200719 yr Author comment_164578 do they sit behind the brakes? i got no problems pulling htings off to take a look and learn a thing or two Report
February 19, 200719 yr comment_164682 the best way to tell is to take the wheels off and spin the rotors/drums. if one (or more) spin with more resistance than the other side then you know its a bearing. I recommend you take it to your mechanic, he could even diagnose the problem for you. Report
February 19, 200719 yr Author comment_164787 my mechanic is my uncle at goodyear, he will tell ME don't worry about it and to save the money and not waste it on this car. Report
February 19, 200719 yr comment_164806 Take it to another mechanic that isnt your uncle :lolcry: Report
February 20, 200719 yr comment_164872 Mine gets very noisy at top speed because of exhaust. But i did just recently get the bearing in the driver's side rear wheel fixed and replaced..mechanics charged me $140, don't know if that's any good or not, (being that i'm a female and i just wanted it fixed) because of hearing a "rolling" noise at low speeds. When i got the car back, the noise was still there, and we discovered it was coming from the other rear tyre. So we jacked it up ourselves, had a play round with the wheels, took them off, put them back on, tightened them up etc and it seemed to go away. Haven't had too many problems since. Don't know if that helps or not, good luck :lolcry: Cheers ~*CaRz!*~ Report
February 20, 200719 yr comment_164876 Mine gets very noisy at top speed because of exhaust.But i did just recently get the bearing in the driver's side rear wheel fixed and replaced..mechanics charged me $140, don't know if that's any good or not, (being that i'm a female and i just wanted it fixed) because of hearing a "rolling" noise at low speeds. When i got the car back, the noise was still there, and we discovered it was coming from the other rear tyre. So we jacked it up ourselves, had a play round with the wheels, took them off, put them back on, tightened them up etc and it seemed to go away. Haven't had too many problems since. Don't know if that helps or not, good luck :lolcry: Cheers ~*CaRz!*~ The only noise we could hear from the left rear was the clicking/clunking one, which was narrowed down to a loose wheel nut (fixed by me, very hard job....:lolcry:). However, after taking the wheel off to have a look under the rear end for some possibly loose suspension mounts (just in case they were the cause), I forgot to fully tighten up the wheel nuts again (all of them), and they slowly worked loose. Tightened them all up, and the noise went away completely. Report
February 20, 200719 yr Author comment_164939 thanks guys, I'm still yet to have a good play with it, ive got my parts to give it a service, so ill do it all in one day. cheers. Report
