Sigma Control Arms
hmmm. so i need corona LCA's, and do i need radial arms and steerin arms as well???
I'm pretty keen on about 2.5-3* camber on the front, so i mite try and find some some gh sig ones...
dunno, i guess its a bit of try and see what i like when it is driving...
cheers for the help guys, any other good ideas???
http://www.ae86drivingclub.com.au/forum/in...8&hl=camber
BTW, i have Camber tops and NCRCA's on my car and have -3 degrees. Thats with the camber tops set about in the middle. Handling is awesome, but as you would imagine it does understeer a little in the wet, but nothing the clutch can't fix haha :D
Edited by ae71neo
Early Sigma LCAs, the ones with PRESS-IN type ball joints are the ones to use!!
The later model LCAs with BOLT-ON balljoints give you about 6deg neg... and that is stupid, excessive, and dangerous!!
You can force the bushes into the Corolla crossmember, but a much better option would be to grind a bit off each end to make them fit properly.
Using longer LCAs will pump the front wheel track out too... And it makes the stance of the car look a bit strange. Find some pics of my KE36 Van and not the differences in track widths.
Good Luck
