May 20, 201115 yr comment_525399 yeah 4stud. At the moment I have ke20 jap diff with ke55 axles for 114.3 pcd but I don't expect it to last long behind the ca. Once funds allow I'll be going r31 with lsd and billet axles Report
May 20, 201115 yr Author comment_525401 R31 is the beez kneez... As I have the hilux, easier for me to stay with the ford 5stud pattern. Report
May 22, 201115 yr Author comment_526099 And sorry to Nathan (JustAlloyRadiators), had to hack at his radiator as I removed the stock mounts from the rad support. hehe Edited January 25, 201214 yr by HIGH ROLLER Report
May 22, 201115 yr comment_526110 Hey Mate good progress keep it going will be awsome when its finished :y: Report
May 22, 201115 yr Author comment_526112 Thanks mate. yep should be neat and quick when it's done. some more work on it tonight, finish flaring the hard lines. Also gotta order my fittings today from Summit Racing in the states...they got good deals on fittings. Report
May 23, 201115 yr Author comment_526245 flaring the hard lines for the sleeve/nut to attach a fitting: Fuel tank 044 feeds: JAR radiator, mounting tabs removed, ready for custom mounting with; 2 spuds on each side of radiator & a sheet-tab coming off the intercooler to spread the load. Report
May 26, 201115 yr Author comment_526970 Just ordered a RWD alternator bracket and tensioner from the States. Unfortunately the one I grabbed off you Shane was not the one I needed, as it didn't match up with the RWD water gear I have. If Anyone's after a 4age alternator bracket and tensioner...I assume it's a FWD one...let me know: I think for the FWD alternator bracket to work, you gotta be running FWD water gear... Report
May 28, 201115 yr Author comment_527568 Intercooler bottom tabs done Radiator tabs in the making Done! Fuel hard lines done, just need to line them up properly and run soft hose to pumps. Report
May 29, 201115 yr Author comment_527593 Thanks man, yeah I'm very happy with how it all come out...nice and neat just how I wanted it, with a bit of bling factor. Report
May 29, 201115 yr Author comment_527762 Thanks jase, your car is an inspiration for the kind of neatness I want to achieve. Report
