Ke70 Panel Van With Whats That, Efi Omg
Hey Hey,
I bought this yesterday for $500 which i thought was an alright price for a Ke70 panel van.
Specs:
5K.
5 speed.
Fusion 6x9's and fusion 6's.
Leaf sprung S series diff.
1 piece tail shaft, Sedans have a 2 piece item.
1 glass rear side window, The rest are metal.
Pictures:
New dash going in when i get some more time.
Edited by AE70
Good to see you back in an e7....
and no you can't have your seats back :wink:
Dang it. Yeah it feels good. Leaf sprung S series surprised me a bit as this is only the 2nd leaf S series i have seen.
The tail lights on the imported panos look much better than the adm wagon ones... just don't go cracking any they'll be a bugger to find
That plastic fantastic steering wheel needs to get the arse asap though
I have wagon lights in the shed so i might pull them out and have a look, The right hand side lens is a bit dodgey.
I've got a decent condition rhs pv tail light here at ipswich if you want to come get it. $10 its yours.
Nah I'm gonna let this shell go, Floor is f@$ked and I'm not spending 1100 do get the dent fixed.
EDIT: Since i like it so much I'm going strip it out and make a auto cross car/skid pan car etc.
Edited by AE70
Well i found a slide hammer in time so it didn't get striped down.
new rims.
13x6 +12 advan A3D's
Dent pulled out today with lots of swearing and throwing of tools.
Wheel alignment done. Just need to fix the exhaust and put dash back together.
Going EFI now using 4ke gear, Yes a 7k manifold is better but its a daily so i see the need to change it.
Since the 4ke ecu is fuel only thats not being used is i want fuel and ignition.
AFM is being turfed aswell as I'm going MAP.
Throttle body might be getting turfed and replaced with a 3.8 one if it runs it ok.
Dizzy will be locked so it can't adjust the timing by itself by vaccum.
Meh I'm tired will explain the rest when i put it together.
