Ae71 And Ae86
hey ive just brought a 1984 ae71 and have been told that some ae86 parts would fit the ae71 and i am in need of new suspension and wanting to no if the ae86 1984-85 shockers would fit my car
The KE70s came out with 2 different size inserts for the front struts. Not sure if the AE86 ones are the same, But you can get a set of ae86 struts and steering arms and bolt them in...
AE86 front struts are different but interchangable as said above.
Rear is the same.
thanks for all the info but would all ae86 struts fit on the front or what
If you put the AE86 struts in you will also have to change the strut tops.
why bother with AE86 suspension when i hear that S13 nissan style coilovers will bolt straight into an AE71 with very little trouble :P
lol no its a bitch, you need the s13 brakes an lca's and a whole bunch of patience.
  • 4 weeks later...
blah blah blah you need a whole bunch of patientce to work on a corolla :locked: :D
