Trufauru Posted October 25, 2007 Report Posted October 25, 2007 hello to all my 4K is leaking trough the oil pan gasket and i have to change it my question is... do i have to remove the engine form the engine bay or i can change the gasket from below??? thats it, thanks in advance Sebastian Quote
irokin Posted October 25, 2007 Report Posted October 25, 2007 It is possible to remove the sump without removing the engine (Ive done it) but its a lot of stuffing around. Far far easier to remove the engine. Quote
philba Posted October 26, 2007 Report Posted October 26, 2007 What about just lifting the engine up a couple of inches? Quote
irokin Posted October 26, 2007 Report Posted October 26, 2007 Thats pretty much what you have to do. I might have dropped the cross member as well, can't remember. Seriously, just take the engine out, you will regret trying to do it with the engine in. Quote
Trufauru Posted November 7, 2007 Author Report Posted November 7, 2007 well following your advise i lift the engine to change the gasket, but one nut didnt colaborate so i have to remove the engine and as is said in the rollaclub faq i increase the oil pump pressure as well i have no pics of the first part :D so here we go it looks good not the best place to put an engine, but... there is something missing here check out the gearbox :sob: :o the competition extractor :evil: :( the starter new gasket in my help, my grandfather 89 years old after 8 hours its back in BONUS a 4Kless *E70 the new Corolla "Powered By Trufaz" Quote
LittleRedSpirit Posted November 7, 2007 Report Posted November 7, 2007 Love the last photo. Reminds me of Des. Quote
Bulant22 Posted June 30, 2016 Report Posted June 30, 2016 Did you use a sealant anywhere on the gasket? My 3K keeps pushing the "half moon" section around the rear of the crankshaft out. Quote
altezzaclub Posted June 30, 2016 Report Posted June 30, 2016 Don't do it up so tight Bulant, and if you take it off use a silicon sealant on both sides. I think the common problem is to screw them up so much it squeezes the rubber out, but overall its not a brilliant design. A rear leak is very common, and the hardest to get to if you want to fix it. Quote
