sixsixone Posted January 26, 2008 Author Report Share Posted January 26, 2008 I would use the repo extra cut as it has got no silicons or additive's and can be painted over easy. for badly oxidized areas sand lightly with ultra fine wet and dry sand paper first. Ahh, i got the yellow one. Smeh. Cheers for the tip. Quote Link to comment Share on other sites More sharing options...
sixsixone Posted January 27, 2008 Author Report Share Posted January 27, 2008 Bogging + Fibre-Glassing is almost done. All done apart from the rear guards. Shoulder drills, lol all this rubbing back is hard work. Starting to take shape. :) Took her for a drive last night, (first time ever) and I like, clutch is a bit too close to the floor so I'll adjust that. Gonna paint a few bits and pieces in the engine bay later too. Gotta get some paint. I think the colour code is BC. But can anyone confirm that? Cheers Quote Link to comment Share on other sites More sharing options...
sixsixone Posted January 27, 2008 Author Report Share Posted January 27, 2008 (edited) All bogging and fibre-glassing is done. And everything apart from the rear guards are rubbed back. Gave the bonnet a cut to see what it came up like, tis not too bad. Anyone know where to get touch up paint? I just needa prime + then cover the primer for now. Will look into paintjob later if I don't find a KE70. http://i269.photobucket.com/albums/jj48/ja...27012008270.jpg - My shiny bonnet. :hmm: Not too bad considering it has been out in a paddock for 2 years. Cheers guys. Edited January 27, 2008 by sixsixone Quote Link to comment Share on other sites More sharing options...
Clapped out Posted January 27, 2008 Report Share Posted January 27, 2008 Any pics of the rust repairs fella? :hmm: cheers phatke30! Quote Link to comment Share on other sites More sharing options...
sixsixone Posted January 27, 2008 Author Report Share Posted January 27, 2008 (edited) Any pics of the rust repairs fella? :hmm: cheers phatke30! Lol, yea. Keep in mind this is the first time I've ever done this so, my jobs not %100. I rubbed back a little bit too much in places, but meh. Cheers http://i269.photobucket.com/albums/jj48/ja...27012008271.jpg http://i269.photobucket.com/albums/jj48/ja...26012008268.jpg Edit: And the guard I showed you needs a bit more rubbing. So yeh. The other sides the same. All the same places minus the fuel cap. Also Just wondering, I donated but didn't get a contributor thing, I feel ripped lol :S Whats the deal with that? Edited January 27, 2008 by sixsixone Quote Link to comment Share on other sites More sharing options...
Murd 55 Posted January 27, 2008 Report Share Posted January 27, 2008 wow. good job hey. I'm impressed =] keep us posted! Quote Link to comment Share on other sites More sharing options...
NickZ Posted January 27, 2008 Report Share Posted January 27, 2008 are you adding metal,welding or just bogging over it? Quote Link to comment Share on other sites More sharing options...
sixsixone Posted January 27, 2008 Author Report Share Posted January 27, 2008 are you adding metal,welding or just bogging over it? Rust converter, cutting out old rust (like big bits) Sanding back, using wire + bog. On the bigger holes, like this, http://i269.photobucket.com/albums/jj48/ja...24012008246.jpg Same as above, but fibre-glassed from the inside, then the outside, and then bogged over the top and sanded back. Would have cut out the metal and welded in, but the cars only a temp. Cheers Quote Link to comment Share on other sites More sharing options...
Clapped out Posted January 28, 2008 Report Share Posted January 28, 2008 You have done really well for a first timer, good work! And i hope you do get another car soon because the rust will more than likely come back within 6 months, cheers phatke30! Quote Link to comment Share on other sites More sharing options...
sixsixone Posted January 28, 2008 Author Report Share Posted January 28, 2008 You have done really well for a first timer, good work! And i hope you do get another car soon because the rust will more than likely come back within 6 months, cheers phatke30! 6 Months.. Eeek. Lol. You serious?? Cheers mate. Well. I'm loookin for a KE70 as a daily, but I also want a half decent 30/early 55 as a project. But we'll se. Hopefully have a job soon too :hmm: = $$$ Cheers Quote Link to comment Share on other sites More sharing options...
KE30_KE35_KE55 Posted January 28, 2008 Report Share Posted January 28, 2008 You have done really well for a first timer, good work! And i hope you do get another car soon because the rust will more than likely come back within 6 months, cheers phatke30! If the panels have been rust converted, sealed with fiberglass matting at the back of the panel then painted how will the rust come back? Rust needs 3 things 1 steel 2 Oxygen 3 Moisture take any one of the 3 away and you can't have rust. you should be able to stop moisture and oxygen by the steps taken fingers crossed. Quote Link to comment Share on other sites More sharing options...
sixsixone Posted January 28, 2008 Author Report Share Posted January 28, 2008 Just put together some comparative pictures. Heres how it looks. http://i269.photobucket.com/albums/jj48/ja...omparative3.jpg http://i269.photobucket.com/albums/jj48/ja...omparative2.jpg http://i269.photobucket.com/albums/jj48/ja...omparative1.jpg So yea. Cheers Quote Link to comment Share on other sites More sharing options...
Clapped out Posted January 28, 2008 Report Share Posted January 28, 2008 (edited) If the panels have been rust converted, sealed with fiberglass matting at the back of the panel then painted how will the rust come back? Rust needs 3 things 1 steel 2 Oxygen 3 Moisture take any one of the 3 away and you can't have rust. you should be able to stop moisture and oxygen by the steps taken fingers crossed. Yeah mate, thats true, although there is always the chance of an edge being missed if overlooked sparingly! Sixsixone, just an idea so that the problem can be prevented from occuring later on in the future, just check the condition and any signs of water leakage of your boot seal, tail light seals, rear windscreen seal and rear side air vent seals, just my 2 cents worth, cheers phatke30! Edited January 28, 2008 by phatke30 Quote Link to comment Share on other sites More sharing options...
sixsixone Posted January 29, 2008 Author Report Share Posted January 29, 2008 (edited) Hey guys. Not much happening except I decided to put a muffler that i got for free on, instead of the stock one. The exhaust still has a resonator before the muffler but yeh. This is just a vid of dad revving it - http://s269.photobucket.com/albums/jj48/ja...29012008058.flv (About 1.8 meg) Got one of the car in action, but its 35 meg and I dunno how to make it smaller *sigh* so if anyone wants to tell me I can upload that one also. Cheers. Oh, and hopefully will get the rest of the bodywork done this weekend. Yeah mate, thats true, although there is always the chance of an edge being missed if overlooked sparingly! Sixsixone, just an idea so that the problem can be prevented from occuring later on in the future, just check the condition and any signs of water leakage of your boot seal, tail light seals, rear windscreen seal and rear side air vent seals, just my 2 cents worth, cheers phatke30! Hey mate. Yea, we're going to re drill some drainage holes in the bottom of the boot, where all the rust on the guards was, as well as some others (dad just said he'll do it). Will check the seals and stuff too, cheers mate. Edited January 29, 2008 by sixsixone Quote Link to comment Share on other sites More sharing options...
sixsixone Posted January 30, 2008 Author Report Share Posted January 30, 2008 Hey guys. Finished the bogging today, bit more rubbing back. Man it takes lots of effort ;) Dunno what paint to use now, where should I go? The colour code is BC, but how should I do the touch up. I have a spray gun + compresser and all, but might just buy a can or two, if I can get matching colours. Anyone reccomend a place? Also, lookin to buy ARM Racing Seat covers, (Year gay i know, but the seats are shot and need covers for the time being) So does anyone know what size I'd be looking at for the rolla's seats? Cheers Quote Link to comment Share on other sites More sharing options...
