I Need Some Help
I just put champion spark plugs wires, champion Cap aand rotor, and ngk SPrk plug.
Know my 1977 corolla bogs out but has alot more power, can tell me why this might be happening?
Edited by Corollaspeedracer
Set the timing on the distributor.
Once you've done that, adjust your fuel mixture by screwing the idle mixture screw in until the car starts to idle funny (don't screw it all the way home tight as it will damage the end of it thats inside the carb) and then unwind 1.5-2 turns.
Let us know how you go :D
Edited by Raven
SWEET, just found how to properly set up the mix. mines been running rich ever since i put the KE30 carb on it. cheers raven.
CHEERS
Ryan
CHEERS
Ryan
+1!
now wheres the mixture screw on a 4k ?n and what u mean idle funny?
mine already idles at frikn 1.6k lol, party due to about 13btdc timeing
cheers
-Alex
+1!
cheers
-Alex
right at the bottom of the carb on the strut tower side. the screw itself looks the colour of brass and has a spring underneath.
when i did mine this morning i screwd it in till it sounded like it was gonna conk out (because your just about stoping the flow of petrol) the screwed it out (counter clockwise) 1 1/2 to 1 1/3 turns. now the tacho and pertol gauges don't race each other :D
Also ho do you check the points gap??
CHEERS
Ryan
Edited by KE25 KID
points gap = take off dizzy cap and turn motor over by hand. ON the distributor shaft you will notice it is square shaped.
You want the points to open up on one of the cams by turning the motor over by hand and stopping it when the points open up.
Then set your points gap. I can't remember what the gap is though.
Someone got a workshop manual to specify what the points gap is meant to be?
yes anyone got the points gap? i need it stock 4k
Can anyone tell me what the configuration of the Dist. cap and wired, and which spark plug is number1.
if anyone has diagram or pic of there engine that would help , heaps
thanks
This is the settings for a 3K (sorry thats all i could find)
Firing order: 1342
Points Gap: 0.016-0.020inch
Timing: 8deg BTDC
Hope this helps a bit :lolcry:
Dougy :)
Ok i this'll sound a bit dumb but how do you set the timing? Do you line up the timing mark on the timin cover and turn the dizzy round till the rotor lines up with #1 on the dizzy cap? never had to do it before but this seems like the way to do it.
CHEERS
Ryan
