Ok so i took the ke70 for thrash and now it wont run on all 4 pots, 3 and 4 have died. Runs on all 4 over 3,500 RPM but under that its really lumpy.
Has spark and fuel so I'm suspecting rings blown out or maybe valve sticking open or something along those lines.
Any suggestions ?
Edited by AE70
Cap, leads, valve clearances, gunged up plugs? Done a compression test?
Cap is good, swapped some of the leads around its still shitty on 3 and 4. Compression test tomorrow.
Bent push rod maybe ?
Valve bounces at 6,500 rpm. So compression test tomorrow after work and i will rip the rocker cover off too.
I couldn't get the compression tester from work so I'm just going to pull the inlet manifold off in the mean time.
