April 30, 200818 yr comment_243030 seems like ke20, 25, 30, 55 front damper inserts (shock absorbers) are the same fit? if this is the case it would make it much easier to track down absolete listings like ke20 and use listings still avaliable like ke55. pedders monroe rear dampers are different types but usually much easier to find than the front inserts. Report
April 30, 200818 yr comment_243035 I'm eventually going RA60 Celica front struts converted to coil-overs :rocknroll: Edited April 30, 200818 yr by Raven Report
April 30, 200818 yr comment_243079 "wholesale suspension" in sydney have been using a KONI shock in ke20s (front) a lot. not sure of the part number but they are adjustable ones. Report
May 1, 200818 yr comment_243261 yeah i got some koni yellows in mine , but needed spacers put into struts for them to fit , not sure of part number but i have it at home Report
May 1, 200818 yr comment_243398 Ive got Koni AW11 MR2 rear inserts in the front of mine(modified strut though) and Fiat 124 model konis in the rear. They seem to work well and are good value. Report
May 1, 200818 yr Author comment_243448 ah sweet seems there are a few options then, anyone have part numbers + prices? Report
