1 Question :)!
Just a question about converting from a 4k to the 4age, Do i need to change my tail shaft? or diff?
Gear box and tail shaft probably, you failed to tell us what type of rolly the 4k is in. :yes:
soz :y: it's in a 1983 ke70, gunna do a 4age conversion, so far i have...
ae71 engine cross member
ae71 gearbox cross member.
Ae71 manual pedal box with hydraulic clutch master cylinder.
Ae71 metal clutch line
ae71 metal engine mounts
ae71 rubber engine mounts.
ae71 gearbox stays.
ae71 sandwich plate.
Is there anything else?
Edited by interlopr
ae71 radiator
ae71 gearbox
4age
Loom
Ecu
Intake to suit RWD
Extractors
Ignition accessories
Alternator
AE71 or AE86 starter motor
Chunky cables for starter, alternator and grounds
Uprated battery
Fuel System with lift pump, high pressure pump, and surge tank, or JDM AE86 fuel tank
Fuel Filter
Thermofan
Clutch and Flywheel
Throwout bearing
Spigot Bearing
Slave Cylinder, either from AE71 or AE86 tosuit the gearbox you get.
Edited by LittleRedSpirit
One thing which people often miss out for the ECU/loom is the third plug on the ECU which connects to the body loom, you'll need to get one of them too.
Correct me if I'm wrong but unless you made up your own relay setup you'd need the third ECU plug and the special "Circuit opening relay" thing in order to trigger the fuel pump. Or does this apply only to small ports? I guess you don't NEED it as such but it would make a neater job.
there are 3 plugs for the ecu on a bigport, not 100% sure for smallport, But i'd say they might be similar. Then you have another part of the harness that plugs into the body harness to feed battery/ignition/frame/crank signal etc..
need an ae71 tailshaft to use the standard ke70 diff
you say u have 4ac rubber mounts and metal mounts, do you need both of these?
if not can i have a pair that u don't need lol, I'm soon to be putting a 4ac in my 70
Yes, you need every plug, bigport ecu plugs are the same as SV21 3sfe, easily had at the wreckers. Smallport is the same deal but with a different style of plug.
I'll see what i have left over :)
