Ok i have an $800 devilbiss compact spraygun and pressure pot setup!
i've been told that a supercheap auto compressor won't give the pot enough pressure.
then also two of them linked will presurise the pot but won't atomise the gun
and three joined will atomise the gun but not for long.
i've been lookin at a lot of different compressors.
3 phase, diesel, petrol, electric.
they all have different tank sizes and flow rates.
now what do you think i need?
can i get away with a smallish tank but a really good flow rate?
or do i need a large tank more?
i just don't know!
i need a compressor to be able to spray a whole car with!
to be honest, i can run a 3hp 15amp compressor to feed a a gravity feed gun all day without a drama at 50 psi.
but a sander its flat out holding 70 psi. so it really depends how much air you really are using. whats the CFM on the gun?
do you have access to borrowing compressors? just try and see what can keep up and what can't.
i usually run my 3hp 3 cylinder belt drive in conjuction with my 2.5hp direct drive and with the two it will keep 80psi to the sander for an hour straight, but the water trap ends up filled.
trouble with smaller compressors is they work much harder and breathe alot more water than a big f@$k off compressor that just lumbers along and doesnt batt an eyelid at flowing 3 guns at the same time.
Unless your house has a 3 phase outlet its out of the question. Jono should be able to shed more light on 3 phase stuff.
youll need a decent size tank so you don't run out of air whilst spraying and even if it kicks in then it will probably be too late and you will have inconsistent air BTW, is the gun a GTi? ($800 is a bit pricey depnding on which rung it is on however) if so when it comes time for pots and nozzles etc, get a quote off your local guy then pm me and ill try and beat it (include all part numbers quoted on")
an australian made MCMILLAN 3hp 16cfm will do the job.
expect to pay for the privilege tho, around $1020 inc GST.
we sell heaps of MCMILLAN compressors, no probs.
bigger tank equals longer air delivery between motor running, equals cooler motor equals motor longevity.
hope this helps.
i can give u the name of a mcmillan distributor in adelaide if you like, or i can have one shipped from melbourne for about 80 bucks.
most compressors are advertised as displacement as it makes tham sound better, but even though some others advertise 16 cfm, there free air delivery is a lot lower.
i don't have the FAD specs on me at the moment, sorry.
maybe at www.mcmillan.com.au ?
