.... I also have it on good authority, that when/if the springs jam internally, that having a second redundant throttle return spring doesn't do much. Blueys carbs had both springs broken, and the first thing the carbie man said was "Had your throttles jammed open?" When I told him no, and I run a second return spring, he told me it didn't matter, it'll jam anyway if I have a second spring or not. It doesn't happen a lot, but it does happen. *shrug* I'm not pulling my Webers off because they may jam.....
same could be said about the whole of pf
Someone once told me (I overheard it somewhere, so it could be false) that Rollaclub was on the Internet too... That's scary...
They do actually have quite a few knowledgable genuine people over there.
Its just a handfull of wankers (pun not intended) that ruin it...
Same as many other forums ie Toymods etc. Very unfortunate, but true.
yeah but i know most of the main rollaclub members well enough to be able to tell wether they're full of crap or not :greenbounce: big forums you can hide behind a name and say whatever you want
