Ke30 2 Door 20valve Conversion
if you notice the bottom of the lower part of the sump is angled slightly for the lean of the engine, it should be level.
hard reving my cause the oil to stay in the head causing less oil in the sump plus its angled to the right, the pick up could come out of the oil depenging on your driving style at the time. ive seen a number of the 20v engines spinning a bearing on the crank, not saying this is causing it but they do seem to have a oil issue. Better safe than sorry.
If you notice in my sig picture youll see my 20v leaning to the left for that reason as this is my second engine, the first spun a bearing.
Ok thanks for tip:)
By the way does your 20 valve have poor bottom end pull? I know it produces good power at higher revs but i am wondering if it needs to be re-tuned?
  • Replies 53
  • Views 49.7k
Ok thanks for tip:)
thats the nature of the 20v.
oh I don't know about that my 20v had heaps of mid range power with what felt like a tottaly linear power curve, but what may seem like heaps to me may be crap to you, without a dyno who knows eh?
mine is crap downlow, i find if i don't get the revs up in first gear second seems flat and then through the rest of the gears feel slow, Giving it heaps of the line and changing around 7500+ it feels like it goes with lost of power, But thats a 20V engine for you, ive got my VVT coming in at 4000rpm and then the rev start to climb alot faster than below that and you can feel a little more pull.
  • 3 months later...
Hello,
I got it re-tuned with the vvt coming on way earlier, like between 2000 and 3000rpm, way more bottom end power now. They are heaps better with the vvt re-set.
Chris
Hello,
Chris
what computer you got??
Running a Microteh ECU mate.
  • 4 weeks later...
Hey mate i'm just curious how you went about making up the engine mounts for your 20v setup. I'm looking to put one in my gf's ke55 in the next few weeks.
  • 2 years later...
@ cobba, hey I really like the front bumper, where did you get it or get the style from. I would like to see how the back is done too if you could post some pix.
