August 7, 200818 yr comment_266819 Background story: I bought this ke20 in 2006 in below average condition and have spent the last three years fixing rust, stripping the entire under body, the interior and exterior paint. The floor pan, engine bay and under body were coated in por15, while the exterior received a bare metal respray. Yes i have an OCD . :eatlead: Only just recently I finished painting it and the parts have been going back on. It has: -te27 Coilovers with ae86 jdm calipers -te27 steering arms -t3 RCAs -T series diff (I believe off a t18) with corona avante discs -lowering blocks -Overhauled all balljoints, tierods and bushes -Solex locks -Vitaloni mirrors -townace chaser rims -Bolt on flares -Custom front lip -Fully seam welded Plans: 4age black SSR reverse mesh rims with some dish Custom instrument cluster Here's a few pics: 2006: 2007 Edited January 29, 201214 yr by Pieman Report
August 7, 200818 yr Author comment_266822 2008 pics coming shortly Edited August 7, 200818 yr by Pieman Report
August 7, 200818 yr comment_266844 Project "bruno" is very good Project "paint rolla" The best Report
August 7, 200818 yr comment_266845 Project "bruno" is very good Project "paint rolla" The best Report
August 7, 200818 yr comment_266850 Awesome job man, its good to see years of persistence paying off. Its also good to see rust removal done properly. It seems to be a rarity these days. can't wait to see 2008 pics :eatlead: Report
August 7, 200818 yr Author comment_266858 Rubbed back and knocking in the high points: I had major issues with the drivers door. It had a huge ripple and had seen a lot of bodywork, therefore making it similar to the surface of the moon and thin as a coke can. I thought.. Bugger it I'll fabricate a partial door skin! Turned out well! The handle and lock hole line up perfect! Still have sloppy hinges though. :eatlead: Gave the door a good prime and wet sanded everything to a polish, including the interior areas that aren't covered in trim. Things were masked and the car recieved 5 coats of base BMW Schwarz II acrylic. I sanded it back after the 4th, gave it a fairly thinned out final base then 3 coats of clear. I've given it a light buff and heare are the results: More to come. :bash: Report
August 7, 200818 yr comment_266859 Man, you've got some skills. Did you use gas or gasless MIG for your panel work? Report
August 7, 200818 yr Author comment_266862 Man, you've got some skills. Did you use gas or gasless MIG for your panel work? Gasless. Not great but it's ok for doing a series of tacks on sheet metal. Report
August 7, 200818 yr Author comment_266868 Where did you get the bolt-ons? Off ebay, some guy in Thailand. They are not te27 copies though they're universal flares. I modified the arches to suit them. The rear arch was a nightmare. Had to bridge the quarter panel with the wheel well with sheet metal (lots of singed hair welding in that tight spot). :eatlead: Report
August 7, 200818 yr comment_266873 Off ebay, some guy in Thailand. They are not te27 copies though they're universal flares. I modified the arches to suit them. The rear arch was a nightmare. Had to bridge the quarter panel with the wheel well with sheet metal (lots of singed hair welding in that tight spot). :eatlead: Geez, it sounds like it would have been easier to make your own bolt-ons! LOL. Report
August 7, 200818 yr comment_266875 Awesome job mate ! Loving your work on the door, very well done. :eatlead: Keep the updates coming. Report
August 7, 200818 yr comment_266891 some say....he made armour for heath ledger....some say he has a welder for an arm.......all we know is....hes called the stig. soz watched too much topgear V. nice :eatlead: Report
