September 21, 200818 yr comment_276447 Hey fellas, My fuel pump gave in on Saturday... so after much running around on the side of the road in the heat on Paramatta road, i got the new part, but it didnt have a return? Obviously there is no issue with this, but why would they discountinue it... ive just got a screw sitting in the return line right now is that ok? Report
September 21, 200818 yr comment_276453 Do you have a ke70? K'sevs had return lines off the fuel pumps, ke30-55 etc didn't. You probably got a 30-55 type fuel pump! :y: Report
September 22, 200818 yr Author comment_276461 hmmm yeh sorry, its a KE70... the pump was the suit the KE70 4k. Does the fact that it doesnt have one present an issue? do i just block the return line? Report
September 23, 200818 yr comment_276896 If you block anything to do with fuel, do it properly, with a decent clamp. Hate to be a safety jerk but I've seen a few cars go up in flames, it's well worth the few bucks for a proper hose clamp etc :dance: Report
October 4, 200818 yr comment_278961 I think my fuel pump has died too I got no fuel coming through the carby and no fuel in the fuel line from the fuel filter would i be correct in thinkin the fuel pump has carked it?? so for the hi jack! Report
October 5, 200818 yr comment_279203 That would be a pretty fair indication that the pump could be shagged. Report
October 5, 200818 yr comment_279247 Check all the screw around the pump body. I had an old Galant and the pump died, just tightened up the screws on the pump body and resealed the diaphragm and it was all go! Report
October 12, 200818 yr Author comment_281063 the process of elimination i used was to check if there was fuel coming into the carby, which it wasnt, then the line from the pump to the carby, there was but nowhere near the required pressure Report
November 8, 200817 yr comment_288206 is there supposed to be a spacer between the block and the fuel pump on a ke70? Report
November 8, 200817 yr comment_288324 Not sure, but there was a spacer on my 4k i got in me KE30... so id assume so mate! Report
November 8, 200817 yr comment_288329 yea because randomly the pump stoped pumping yesterday as i was going to start her up, ill take a look into it, could it be the fuel filter? Report
November 9, 200817 yr comment_288350 ok well ive put the spacer on as well as a new pump and gaskets, and when i go to start it its doing the same thing, the fuel filter has barely any fuel in it as well, any ideas? Report
