September 27, 200818 yr comment_277599 wannna know where petrol pump is in an ae82 twin cam 1988 model, need to know asap. I'm a new member. reply or call 0422718596 URGENT Report
September 27, 200818 yr comment_277607 theres deffinetly one under the rear seat (in tank). i assume there's probably one in line from the fuel rail in the engine - trace back the fuel pipe from the fuel rail, and see where it leads Report
September 27, 200818 yr comment_277609 theres deffinetly one under the rear seat (in tank). i assume there's probably one in line from the fuel rail in the engine - trace back the fuel pipe from the fuel rail, and see where it leads if its a twincam model its an intank pump. there is no in line pump :yes: Report
September 27, 200818 yr Author comment_277615 well i looked under seat and thats the sender but must b above the tank, but all is good my pump wasnt gone, thanks, but if any1 can help, it idles around 1200 RPM is that normal, and if any1 can help where it is some more i'd b happy 2 know as for future reference Report
September 27, 200818 yr comment_277632 You have to take the tank out to even see the pump, Idling at 1200rpm is normal if it is cold. Report
September 28, 200818 yr Author comment_277668 Pumps in the tank well it idles between 1200 & 1500 all the time, but doesn't heat up, unless in traffic, stays on cold Report
September 28, 200818 yr comment_277677 well it idles between 1200 & 1500 all the time, but doesn't heat up, unless in traffic, stays on cold They have temperature controlled idling, Does it start to idle lower when it gets warm in traffic? Report
October 8, 200818 yr comment_280239 Sender is in the top of the tank under the seat (3 screws holding down the plate) Fuel pump, as said is in the tank and a PITA to get out/in. If you are going to pull it out (which it seems you arent now) syphon as much fuel out as you can. makes life alot easier, and you don't waste that expensive liquid stuff. Report
October 9, 200818 yr Author comment_280283 any1 need any twin cam parts let me know k. 0422718596 Paul and theses r 4 sale Report
October 9, 200818 yr Author comment_280285 They have temperature controlled idling, Does it start to idle lower when it gets warm in traffic? yeah idles lower once half hot Report
